A crooked man with a crooked bevel
Andrew in Plano
>I bought a 1/2 inch mortise chisel off EBay. Everything is fine except that the bevel isn't square to the chisel. I don't have a grinder or anything like that, just a few waterstones and of course sandpaper. I have a couple of blade holders for sharpening, but I don't see how I can square up the bevel with that. Any suggestions?
Peace
Andrew
Re: A crooked man with a crooked bevel
David Miller from Iowa
>I'd start with a file and get it in the ballpark, then go to scary sharp and coarse sandpaper. It's tedious and uses a lot of sandpaper, but does work.
Good luck, David
Sandor in Boyds, MD
>No grinder here either.
Just get some of the Norton blue Zirconium sanding belts 120 grit at Home Despot and double stick tape them (carpet tape) to a relatively flat board. Use your honing jig and you'll be suprised how fast the metal will come off. Be sure to vaccuum or brush off the swarf to facilitate cutting. I can get maybe a half dozen chsels or plane blades done on a belt before its worn. Its not hollow ground, but it'll shape up the edge ready for honing.
Well you could...
Scott Burr in Ben Lomond CA
>mark a stright line across the blade with a sharpie of equlivent marker and attack it with a belt sander. Otherwise get ready to do the same thing by hand sanding on sandpaper then go to the guide for final squaring and sharpening. Good luck, sounds like a nice workout.
use a magnet to clean swarf
Gerry Doll
Re: Well you could...
Andrew in Plano
>So are you guys saying to hold it vertical and square up the end, and then re-shaping the bevel? That will be a workout.
Peace
Andrew
Scott Burr Ben Lomond,CA
>Try to maintain the bevel as you square it. Less of a workout that way. I hope I'm making sense here...
Greg Sloop, Portland Oregon
>I don't think it makes any difference either way. (Unless I'm really off on my geometry...)
Either way you'll take off the same amount of material, provided you don't over-grind while it's vertical - which it's easy to do. But theoretically and all... *grin*
Cheers,
Greg
