Adam's Mortise Tech.
Mike MacDonald
>Does anyone have Adam's post about his technique bookmarked? My stroll through the archives, while turning up other tidbits of wisdom, was fruitless when it came to finding that post.
Re: Adam's Mortise Tech.
Here is a copy...
>Adam Cherubini on Mortising
1) Identify the datum/face side of the mortised stock.
2) Select a mortise chisel as near as possible to 1/3 the width (or
thickness) of the stock as possible. Don't forget the size of the tenon
shoulders if any.
3) Mark the near side of the mortise (nearest the face) such that the
mortise falls in the center of the stock. (Or skip this step and just
eyeball it like I do!! Works MOST of the time! :) )
4) Using the mortise chisel, mark the ends of the mortise, tapping the
chisel lightly with a mallet
5) Begin the mortise by making a series of cross grain paring cuts, bevel
down, with the top of the cannel barely clear of the stuff. (This is the
step Moxon is talking about). Work carefully, since the chisel could easily
lift a long hunk of grain right out. Just make shallow cross grain cuts.
(Lift the chisel, if you must, or for soft woods) Space the cuts maybe
1/4-3/8" apart. Work from one end of the mortise to the other. Then turn
around and work your way back, this time removing shallow triangular chunks.
At this point, your mortise looks like shallow saw teeth. Repeat this
shallow paring until your mortise is at least 1/4" deep. Only then (or
maybe not even) will your mortise be deep enough to register on the sides of
the chisel. Once you get to this depth and beyond, the sides of mortise
will keep the chisel tracking straight and square.
The technique I use for this step is Moxon's. Hold the chisel blade between
your fingers using your dominant hand, with two fingers behind the blade
(last two or first and last), and two in front. Hold the handle (helve)
with the other (I wrap my thumb over the end). Push the handle using your
dominant hand's shoulder. Support your upper body using your dominant hand.
The tool slides through the dominant hand's fingers. Oh boy! I hope you're
getting this! Anyway, this is a better technique than driving with a
mallet, since your are in complete control and you're not dulling your tool
needlessly. The key is your connection to the stuff and thus to the bench
directly. Much better than baring down on a tool, hoping it won't slip and
ruin your project or bench (yikes!)
6) Continue with your paring cuts using the same technique but with less
caution. The mortise will keep the chisel straight allowing you to cut
deeper and faster. You can make vertical cuts from time to time as
necessary to define the ends. No need to work to the full length of the
mortise. A sharp, carefully used mortiser can easily pare the end grain at
the end of the job.
7) Inevitably, I end of with either a mountain in the middle, with valleys
on either side, or a deep valley on one side, and a high mountain pass on
the other. Regardless, I resort to working bevel up paring the snow off the
mountain's slope, taking a piece of the top away with each stroke.
8) At last you have a deep mortise with flat sides and tapering ends. Only
now do I flip the mortise bevel up and reach for the mallet. Its my goal to
use as few and as light mallet blows as possible.
1/4" x 2 x 2" deep mortise in white pine takes me 5 minutes. Harder woods
may take 10.
9) Set your mortise gage to the mortise you just made. In your mind, rename
your mortise gauge "tenoning gauge".
It might be worth mentioning things not to do:
1) Don't try to "clean up" the mortise sides with a paring chisel. Correct
your tenon if you must. The key to a good mortise is its parallel sides.
The moment you pick-up that small mortiser or paring or firming chisel,
you've relegated yourself to an ill fitting mortise.
2) For the same reason, avoid the temptation to start your mortise with a
series of holes. First, the holes will likely not be perpendicular to the
face you're mortising. Second, your mortise chisel won't work as it should.
You'll be forced to pare out the sides, banging away needlessly. Might be
okay for a barn.
3) Lastly, try to limit how often and how hard you hit your tools. Few 18th
c tools can stand up to routine banging. They're not still around because
someone (Mike Dunbar) wailed on them and used them as pry bars to "lever out
the chips". (OY!)
The key to this technique is the beginning series of shallow cuts. The chisel is held orthogonal to the long grain as you say, the same as you would if pounding. Instead of driving straight down, you work as Ted has said at the lowest angle possible.
You make a series of incisions, producing no chips, on the first past. The next pass, making identical incisions but from the other direction, makes chips. The result is a shallow saw tooth.
Once the depth of the mortise is 1/4" or 3/8", you can stop making careful incisions and start simply paring away. At that point the sides of the mortise help guide the chisel. The process picks up speed then, but I've never made a mortise in the softest of wood faster than 5 or 10 minutes.
I don't feel strongly that this is the only way, the best way or even the old way. I only mention it because it makes some sense and is never discussed.
Folks that wish to try it need a mortise chisel with a huge handle (because you push the tool not with your hand, but with your shoulder). Bob's chisel wouldn't work well for him. This technique probably explains two cherries' and the old english mortisers' handle shapes that many complain about being too large.
Final word- I could be wrong, but it works for me, is demonstrated at
Wmsburg (not that they know everything) but moreover fits into an
archeologically revealed framework- a sensibility really. A kind and gentle
way on wood, body and tool. How this all fits together, I'll leave for
someone else (Eugene Landon? www.oldemill.com).
Adam Cherubini
