marking knives
Brad in Cocoa
>I have been contemplating making or buying a marking knife. What would be a good blade length? WOOD recently did a story and their version has only 1.5" of exposed blade. That seems rather short.
Brad in Cocoa
marking knives
Brad in Cocoa
Brad in Cocoa
Re: marking knives
Dan Moening, in foggy Sacramento
>In my limited handtool experience I've used any number of things for layout/marking.
I've found for general marking and layout where the mark is placed on an exposed surface 1.5" would be fine.
However, for tighter spaces (as is needed for marking pins from tails in DT joinery) I am currently using an exacto blade that exceeds 2".
I'm considering making a marking knive this January when shoptime is more plentiful, and will be interested to see what the general consensus is on this.
Dan.
Re: marking knives
Ted Owen, Pittsburgh
>Do you find an Exacto blade 2" long to flex? I have trouble with even shorter Exacto blades wandering.
Best, Ted
Re: marking knives
>The exacto blade does indeed flex.
I have adopted an unruly technique that uses the flex to an advantage by somewhat pressing the flexed blade upon verticle face. On awkward dance, but its what I have, and what works for me at the moment.
The tendency to wander is due (IME) to the species of wood being marked.
However, your observations are the reason why I'm planning on making my own marking knife soon.
Dan.
Re: marking knives
Jim in Burlington Ontario
>I have several different knives and tried the exacto but it's to sharp and will follow the grain. I prefer my slightly dull pocket knife.
Re: marking knives
paul womack
When marking, I make a light cut, followed by a heavier cut. Attempting to make a deep cut in a single pass is asking for trouble; in particular, with that much force around, it's easy to move your reference (ruler or square).
Excessive force will also tend to make the blade flex - or worse.
Once you've made an accurate shallow cut, it's very easy to make it deeper in a second pass, partially guided by your reference, partially guided by the shallow cut.
This is the same (classic) technique taught by Kingshott for using marking gauges.
BugBear
