Plough plane pics
Plough plane pics
Steve Kubien
Plough plane pics
Steve Kubien
>I was asked to post some pics of my new Knight Plough plane. I would love to but I am completely inept at posting pictures. So, I would like to call upon Steve Knight to show everybody what he's got. Come on Steve, don't be shy.
Steve Kubien
Re: Plough plane pics
steve knight
Welcome to Adobe GoLive 6
Ok here are some pics/ this plane is still kind of in beta testing. I had made several a few years ago but was so fed up with them I gave up. But I got the big again. I had learned how to do some of the things later on that the plane needed.
The plane is about 12� long and about 4� tall. It needs to be a bit taller then the one in the pic. I had to keep the design simple or I would have to have parts made and the cost would skyrocket.
The depthstop is a piece of ipe with a thumbscrew to hold it. The blades rest against one side the body so they are always in the same place no matter the width. The sole is 0-1 as it costs less in the size I need 7/64� the blades I think are �� 3/16� �� 5/16� or 5/8� and 7/8� I have had problems with getting warped blades back from heat treating.
The arms are oak and the plane can be used left or right handed. The fence clamps on the arms with a simple thumbscrew. I may use a more traditional method if the plane works out. But there again I would need someone to make those parts for me.
Steve Kubien
One my version...
Steve Kubien
>Steve and I had a fair bit of back-and-forth correspondence in the design of this plane. What-I wanted. What-he-could-provide-without-losing-his-shirt. That sort of thing.
I had asked Steve to make mine left-handed. He extended the holes for the arms completely through the body of the plane and I merely put the arms in backwards to what many would do. The fence is symetrical along it's length so flipping to the other side of the body is easy. It a pretty slick unit. I haven't had time to hone the irons and get into the shop as of yet. Speaking of the irons, these things could easily be adapted to be mortise chisels. They are really nice and thick!
Thanks for working through this with me Steve. I appreciate all of your work in designing and getting this plane out the door and into my hands.
Good luck with it!
Steve Kubien
Ajax, Ontario
Dean J in MN
>...and when can we order???
-Dean
A Question...
Todd Hughes
>Since unlike tradtional plow plane irons your irons are of different widths where they go though the plane body what keeps the thinner ones from moving around. I am guessing they have slots in them [like original irons] that engage the steel skate at the bottom which helps some to hold them but don't you think they would be more secure if the top section was the same size on all the irons?.......Todd
Re: A Question...
steve knight
>You just rest them against the side of the plane. The sole is flush with one side of the cheek. I had no way to make grooves in the irons for a more traditional approach. This way you always have one side of the blade at the same spot.
I used a thicker sole to help support the wider irons and the �� keeps the flex down.
I had to work around my limited tools and my very limited budget.
Tim of Dublin
>Is that mine?
Is that mine?
Is that mine????
steve knight
>no I just ordered steel for yours. this is the second new one.
Like a kid waiting for Christmas
Gerry Doll
Gee Gerry.....
Todd O. Cronkhite Maine Native in Florida Exile :
>Brand new to handtools and already you're uying Knights? Oh, the future looks bleak for you my friend, bleak, bleak. We'll start looking for a place for you to park your van. You'll be here soon. ;~)
Nice simple little Plough Plane you've come up with Steve.I expect to hear some good reviews about them right after Christmas.
No! For the thousandth time Gerry, that is NOT yours, now go on out and see if you can get that van to start up ;~)
Todd O.
Todd O.
It gets worse.
Gerry Doll
>Still in the process of attempting to learn how to flatten the backs of chisel and plane blades (keep dubbing the outside of the leading edges), ruined a couple of chisels, managed to make all 4 sides of a 200 grit waterstone true to themselves but out of wack with all others.
Current work in progress:
1. Tuning a new #4 record.
2. Fixing my mistakes in tuning a #5 Anant.
3. Tuning an Indian # 78 knock off.
4. Tuning a WW II Bailey 6 with an out of wack sole.
5. Flattening and sharpening a set of LV chisels I made a hash of.
6. Flattening and sharpening a small set of marples bevel edge.
7. Filing the pins on a crown mortise gauge.
8. Truing the side of the above-mentioned waterstone ( Any suggestions?)
9. Tuning 2 new stanley blocks. ( bought from the big orange box)
The top of my work bench, for the last 6 months has been covered by a lapping plate, various grits of lapping powder, 3 or 4 sheets of plate glass, a 25 lb stack of sand paper ( 80 to 400), waterstones (200, 1000, 6000), a DMT plate, feeler gauge, and books on sharpening (Lee, Lee_Nielsen, fine woodworking).
The top of the bench ( cheap plywood construction) is ruined with embedded iron shavings and mud from the waterstones.
The only plane in any decent shape is a #7 that was bought tuned. (Qudos to Walt Q!)
The wife is beginning to think I've lost it, the kids can't recall my name, and I don't think I'll be able to fit all this in the van.
Gerry
Thinking about leaving ww and taking up something simple, like quantum physics.
Truing sides of water stones
>Why would one want to do that?
It's a large stone, 2x8x3,
Gerry Doll
>and which ever side you lay it on, it looks like the leaning tower.
