Shapton Stones...What grits?
>I'm thinking about buying Shapton stones to sharpen my tools. What are the minimum grit sizes to get started and get good results?
Thanks
Tommy
Thanks
Tommy
Re: Shapton Stones...What grits? *LINK*
Pam Niedermayer - Austin, TX
>Have you read the FAQ on the Shapton site?
>Pam,
Thanks, that helps a lot.
Tommy
Andy Lincoln,in Dearborn MI
>Tommy,
Happened to catch this in the latest catalog from Joel at the Museum Of Woodworking Tools,a 3 piece set of Shapton Pro series 1000,5000,and 8000.I wouldn't think much more would be needed.I have conventional waterstones 800,1200,4000,8000 but maybe Santa would like me to upgrade to the Shapton's(I'm hoping Mrs.Claus thinks so,anyways..hint,hint)
Andy
Shapton's
Ed Snow
>I have the set of 1000, 5000, 8000. I only use the 1000 and the 5000 most of the time. My 8000 sits in its box 90% of the time unless I am sharpening my japanese irons then I go to 8000 but I so rarely use them it almost seems like a waste. I would suggest contacting Stanley Harrelson and asking him what a good coarser stone would be so you get coarser, 1000, and 5000.
I honestly see no difference in standard wood or exotics by taking a western plane iron up to 8000.
Harold Blair
>Thomas: I have been using only the 1000 and 8000 for years. After initial sharpening, I only have to go back to the 1000 every once in a while. Also, check out the method that David Charlesworth uses to sharpen. It is outstanding.
Plane Sharpening
