Arcane woodworking terminology, help!
Roy from Cincy
>Hi,
I'm reading an old woodworking book, circa 1908, and it has a lot of good discussion about how to plane rough stock square and true. However it uses some terminology that throws me. For example, every board has the following parts: side, edge, end, corner and arris. The face side is the best side, the one you should choose to plane first and use as a reference for all other work. The face edge is the best edge, which you should true up right after the face side. The end and the corner are obvious, and the arris is formed by the intersection of a side and an edge.
I don't know this word arris. Help. Am I the only one out in the dark here? Rather than call the parts side, edge, end, corner and arris, I think I would have called them face, side, end, corner and edge. What is the right terminology in modern English?
