WAY OT: water pipe noise
Tony Z.
>In the esteemed wisdom of this group, I am posing my porblem to see if anyone here has ever had a similar expeerience. Last evening, around 10:00 PM, I heard a "rattling, vibrating" noise, seeming to come from the bathroom off our master bedroom. Went in there and couldn't find anything wrong. Went downstairs and I could hear it a bit louder. Went down into the basement and it was very loud.
The domestic water supply line, coming in from the water main, had a bit of a vibration. The further along my distribution lines, it got louder. Then it began to diminish. I couldn't find any loose pipe securing fasteners. No water was running anywhere in the house. I examined the water meter and it was not moving at all! Anyhow, where most of the noise was coming from appeared to be a pipe "vibrating" against an I-beam. So, I placed a piece of rubber under it and the noise moderated.
Around 1:00 AM, my Wife and oldest daughter woke up, and naturally, I was awoken also. The noise was ten times the magnitude that it was several hours earlier! Again, I found the same conditions, only this time, I "dampened, with rubber" several additional locations. Also, again, no water was running anywhere and the meter was not moving!
This morning, it was fairly quiet, although there was still some low vibration.
Any thoughts????? Any guidance?????
Thanks,
Tony Z>
