Corrugated Plane bottoms
Darin in Victoria
>What's the advantages/disadvantages of a corrugated plane bottom versus a flat sole? I keep seeing old try planes on eBay and most have corrugated bottoms.
Re: Corrugated Plane bottoms
Bob Smalser, Seabeck, WA
>Spose to be easier to flatten and provide less friction.
I like them because I think they're cool....but I really can't tell any difference in either touted asvantage between "C" soles and solid ones.
John Longwitz-Doraville, GA
>most common explanation I've seen is that they work better (have less drag) on resinous woods. I remember jr. high school shop class and I'm pretty sure only one of the 20 or so jack planes had a corrugated bottom. Don't think it's necessary for most work but if you're a collector it's one more hole to fill.
Lettuce not forget....
Scott Burr Ben Lomond,CA
>The whole shooting board controversy...;)
Re: Lettuce not forget....
Joel Oswald
>My corrugated number five somehow works better then any of my other 8 working planes. It flattens easier, and just slides on the wood like a dream. But maybe I just have a magical plane.... Oh yea, my flat bottom number five does not work nearly as well as the 5C...
Hi Darin,
HC Sakman
>Hi,
Not only they are easier to flatten and cause less friction, they also cause less suction, especially in soft woods.
Chico...
Frank D. in Montreal
>Hi Darin,
I have both kinds of planes and can't see any difference in use at all. I use a lot of resinous woods (fir, pine, cedar) as well as hard woods, and have no preference as to the kind of sole. The only advantage I have noticed is in the lapping (corruated is easier), but corr. soles are a bit harder to keep clean and rust-free (although it's not a huge problem). The advantage and inconvenience pretty well cancel themselves out IMO.
Frank
Thanks Guys
Darin in Victoria
Same as my experience
jim_reed@marietta
>My corrugated bottom planes all seem to work better than their flat bottom cousins.
