Mineral spirits and waterstones
Todd M
>Hi,
I read a recent article in Woodworking Magazine by Chris Schwartz about sharpening chisels. In flattening the back, he uses a DMT diamond stone and he recommends using a little mineral spirits for lubricant. Then he goes to a 1000 grit waterstone. Before I do this for my first time, do I needed to do anything to clean the chisel (other than wiping off the mineral spirits and slurry) before going to the waterstone? I didn't know if contamination was an issue.
Also, do you recommend his same procedure for flattening the backs of plane irons, and if so, how far up the back of a plane iron should I flatten? I'm doing a #4 plane, block plane and LN 62 low angle jack plane.
Thanks for your help.
Todd M.
