ADVERTISE HERE - FREE TRIAL
Building a Japan/American Plane
Chad Boehlke
>Iam building a plane that is a Japan style plane, but its 2 1/2" tall so that Westerners can hold on to the body as they pull it. A woodworker in CA. works with Japanees tools and always had a problem holding on to it. Well I started on it last week. After its done I will post a photo of it. Has anyone built something like this?
Re: Building a Japan/American Plane
steve knight
>I beat you too that (G) but it is a good idea and makes the plane easie to use.
My only question...
>...is what does your design do to the center of gravity of that plane? I know that my SUV has a warning to watch out for rollovers. :-)
Seriously, in general, I believe in keeping the cutting force in line with the cutting edge, to whatever extent possible. A higher body might incline you to inadvertently apply a side-levering type of force when pulling, thereby negating one of the great benefits of Japanese planes.
Just a thought. I'll be interested to hear more.
Re: My only question...
Chad Boehlke
>I bult a prototype and it dose rock a litte, but while useing it, I notice I havt to slow down and make sure it is square on. It teaches a person to be more carefull on being square.
Pam Niedermayer - Austin, TX
>I've never seen anyone have problems holding a Japanese plane, out of probably 40 people. And if you add in Gordon, Mujingfang (sp?), and the like, there are many more who regularly use low slung planes.
Pam
steve knight
>the base may need to be a bit wider is all. I have made planes that are a lot of different hights. othe only complaints I ahd gotten where when I was beveling the sides so only the ipe sole touched the wood.
most likly the body of a japanese plane was built around the blade. longer blades were far harder to make. I know since it was a battle to get longer blades made. it caused all kinds of problems.
Chad Boehlke
>I have the base as 2 3/4" wide by 2 1/2" tall. Thats what the person wants so he is willing to try it. Diff. question, do you use floats? I have been useing blunt "scrapers" that has been working very well, one other old timer plane maker uses the same thing, I can't think of his name.
Chad Boehlke
>Well this person wants it. My prototype is easy to hold on to. I don't have a Japan style plane, so Iam not sure how they operate. I like the over size.
>You typically place your boss hand on top of the plane and secondary hand behind the dai, then pull.
Pam
steve knight
>I have flat end scrapers or sharp files for inside work. my plane designs don't need much inside work though.
