The Haunched and Drawbored M/T Joint - Part I
Bob Smalser, Seabeck, WA
>Part I - The Mortise
One of the strongest joints, the haunched and drawbored mortise and tenon is one of the few that resists stresses in any direction, to include tension, and is a joint that will remain fully functional long after any glue has deteriorated to dust. A basic joint used to join structural members, I�ll walk you through cutting one today by hand to join the top rail to its post for a small work table done in hard maple. Why by hand? Not because I�m some hand tool reactionary�I use machines for the jobs they do best and hand tools for the jobs [i]they[/i] do best�but there are some joinery principles best displayed and photographed using hand tools, and as most teaching today involves machines almost exclusively, newcomers tend to miss the parts where the cheaper hand tool does the job much, much more efficiently than the expensive machine, especially on smaller hobby projects.
Plus, not enjoying any subsidies from major machine or hand tool manufacturers or retailers, I�m free to provide counsel on what�s best for [i]you[/i]�not what�s best for my sponsors.
The basic joinery tools I�ll use are shown above. None except the shop-made mallet are newer than 30 years old and some are almost a century old�yet I could replace all of them in a few months of shopping at flea markets and collectible tool auctions for less than 200 dollars, simply because my first training 4 decades ago as a teenager in a boatyard was in basic hand tool sharpening and maintenance. Yes, the shoulder plane is relatively expensive, but they are indispensable even for machine woodworking and sound but scuffed ones like this Stanley 93 can still be had in the 60-dollar range. 3-tined adjustable mortise gages along with the old Disston saws can be found used for less than 20 dollars, and the large mortise chisel is a recent acquisition as part of a salvage chisel lot that cost less than 5 dollars.
My point is that a newcomer�s first steps shouldn�t be making furniture for the house or that first fancy dinghy, they should be acquiring and tuning the necessary tools and learning to use them in traditional construction of simple benches, shelves, assembly tables, horses and jigs for your first shop. Why traditional construction? Because its study and practice with hand tools will teach you more about your material�wood�than machines will, and it never ceases to amaze me how little even some advanced craftsmen understand about their material. Hand tools allow you to feel how steel wants to move in cutting wood based on the grain of the wood and creates an understanding that applies to obtaining clean cuts using machine tools as well. It will pay off in the long run to your pocketbook, your enjoyment and your skills, as it�s easier on all to make those first irreversible mistakes in 50 cents worth of maple than 80 dollars worth of mahogany.
The mortise should be cut first, and I�ll chop one with the chisel. This is a long, millwright�s mortise chisel made by James Swan almost a century ago. It�s not a �framing� or �firmer� chisel as described by many tool dealers or collectors, it was manufactured primarily to chop mortises in window, door and millwork factories more than for tradesmen, who generally used smaller �sash� mortise chisels more easily carried in a carpenter�s box or shipwright�s chest. All mortise chisels come in widths to match the intended mortise, but these millwright chisels are much longer and easier to hold plumb, much heavier, and combined with the right mallet, much more powerful. And with power comes speed and efficiency.
I set the mortise gage to the exact width of the chisel�
�and use it to lay out both mortise and tenon on the squared-up stock. I darkened my lines with a pencil and drew some otherwise unneeded lines for clarity, but laying out your joints should be done with marking knife and awl, not a pencil. The knife used across the grain and the awl used with the grain is not only more precise, it provides accurate recesses to index chisel or saw, and as you will see, scribes the wood sufficiently to prevent unwanted splitting and chipping while cutting or chopping.
This is a 6/4 by 3� post and a 5/4 by 2� rail, and I�ll do a � by 1 �� mortise a 16th of an inch over deep to house a 1 �� long tenon. Mortises should always be slightly over deep to allow room for glue squeeze out. A 7/8� wide mortise would also be acceptable here. The �haunch� is the 45-degree tenon stub I�ve drawn on the upper face profiles of the stock that increases the gluing surface and aids in the joint resisting twisting stress.
You can also see in the photo above that if the rail is to be flush with the post top, then I�ve crosscut the post too long. You are correct, I have. The post�s short grain on the topside of the mortise will be far too fragile to chop a mortise and haunch without predrilling�and predrilling is unnecessarily slow, so I�ll chop my mortises vigorously and trim the tops of the posts later.
The first two chops are plumb to the work piece and just a bit inboard of the mortise ends. Inboard because that lead-weighted hard maple mallet weighs over 2 pounds, the bevel on this striking chisel is a steep 35 degrees, and hard blows downward tend to push the chisel backwards just a tad. Although it is the cheeks of the mortise that provide the majority of gluing strength, avoiding unnecessary stress or damage at the ends is simply better craftsmanship.
I�ve also marked my required mortise depth on the chisel using masking tape.
The third blow is taken bevel up about a third of the way along the mortise�s length at an angle downward toward the end�
�and the waste levered out, splitting along the grain of the wood. The deep scribe marks from the mortise gage prevent any chip out.
The fourth blow is identical from the opposite direction and that waste levered out. Subsequent blows continue with two plumb blows at each end followed by two angled blows and levering out waste�
�as the mortise gets deeper, the obstruction of the mortise ends force the angled blows increasingly steeper, eventually preventing them from reaching within clean splitting distance from the end blows�the chisel is then flipped and the angled blows struck bevel down to keep the cutting angle sufficiently acute for clean, 4-chop split outs.
Continued�.
Re: The Haunched and Drawbored M/T Joint - Part I
M/T Joint - Part I Continued
Upon reaching the correct depth, the mortise bottom is squared and cleaned by lightly striking the chisel with the bevel instead of the blade back indexed against the mortise end �
�and the top of the chisel bevel used as a fulcrum to scrape the mortise bottom with the edge of the tool. The added leverage of the longer length and larger bevels of these heavier mortise chisels also make this an incredibly clean and efficient technique to get out that last 16th of depth, if you find yourself a tad short.
The haunch is chopped by lightly striking its outline�
�then using a bevel gage or sight line to line up one, clean 45-degree chop. These can also be cut square and a corresponding notch made in the post. Unlike the square ones, the angled one I�m using today is completely hidden�and technically should be called a �miter haunched drawbore mortise and tenon��but that�s a bit of a mouthful for a subject line.
The end result is a clean, accurate mortise done in mere minutes. Depending on the size of the mortise�in average-sized furniture stock and using the right tools, they can be chopped at the rate of between 6 and 20 per hour with very little practice at it�.on many pieces faster than the time needed to set up and test a router jig.
You chop 'em a lot like me...
Scott Burr Ben Lomond,CA
>Excepting I don't use a vice to hold the wood, always told thats a no no.
Nice to see I'm not the only one who "pushes the tape" for marking depth too.
Nice chisel...insteresting profile.
BTW, Another great post no matter what one says;)
Re: M/T Joint - Part I Continued
Dan Clermont in Burnaby
>Thanks Bob,
It's always great to see articles like yours teaching methods. Gives those with little experience a push in the right direction.
Please keep posting your "Methods of Work" and methods of "Tuning Tools or Making Woodworking Tools".
I always look forward to your posts and clear pictures explaining the procedure.
Dan Clermont
Re: You chop 'em a lot like me...
>I was counseled that way as a kid, too....
...and even today I believe that no-vise business is an old saw from the days when vises had wooden threads and shafts.
I was also taught that putting any pressure at the ends of the mortise is a no-no...
...and within reason, I don't buy into that one, either.
Matti Kuikka
>Very interesting. I'll have to try chopping in the vise, which I have avoided due to early teaching. I have a Record made into end vise with 4th pair of wooden (this time beach) jaws just installed and I hope I can apply enough pressure. I have tried holding the piece to be chopped with a holdall but it tends to slide along the bench top and that leads to all kinds of contraptions.
I have a continuing problem with the chips if the mortice is short and narrow, especially as I get deeper. So far the best solution has been to use a narrower chisel to pry them out but it's not very efficient. I'd be interested to know your solution.
IMHO your motivating paragraphs in the beginning make even more sense to me at least than before.
Wouldn't mind having a grandad like you ;-)
Matti Kuikka
Re: Chopping in the vise
paul womack
>If the workpiece is held soley by friction in the jaws, this places a lot of stress on the vise and its fixing to the bench. Even if a spacer is placed below the workpiece so it site directly on the guides and/or screw, it's needless.
Much better morticing workholding is had by placing the workpiece on the bench top. If your bench is truly massive, anywhere will do. If your bench is a little lighter, over a leg is the best.
To hold the workpiece, you can either clamp a piece of scrap DOWN on the workbench, and then clamp the workpiece horizontally to the scrap.
Proper 'G' (AKA 'C') clamps are best for this, since the shock of chopping tends to make 'F' clamps lose their grip.
Alternatively clamp a handscrew to the workbench, and hold the workpiece in that,
In either case, a wonderfully solid support is obtained.
If you really do a lot of morticing, you might consider a dedicated morticing stool/bench.
BugBear
question
chris toomey
>bob
i love your tutorials. i look forward to reading anything you post. you've mentioned before about writing articles for something or someone...these little how to articles need to be put together in a collection somewhere. rather than searching archives for them, is there anywhere these are being stored? i'd love to have the complete volume. thanks again...keep em coming.
chris
I know where *LINK*
Fred G - Cincinnati
>Bob - I hope you don't mind, but I thought your site was too valuable to pass up. And I agree with the rest of those in saying "Keep it coming."
Bob Smalser's Hand Tool How-To Guides
Never Just By the Jaws...
>Just put a smaller spacer block of soft cedar down there on the vise rails to support the work piece and you'll damage neither vise nor workpiece and the durn thing won't slip, either.
Some folks make all of this way too hard.
>Just put a spacer block in the vise so the force is directed to the rails instead of the jaws.
The chips do get smaller as the hole deepens, but if the mortise is cut clean, the chisel used bevel down can be used to flip them out using both hands. I didn't have to remove the work piece from the vise to empty chips once in the sequence shown.
Again....don't worry about the vise....a patternmaker, who used a his big Emmert for everything, would chuckle at somebody concerned about using one.
Re: Never Just By the Jaws...
paul womack
That was the spacer idea I mentioned in my post.
It helps. (*)
But I still prefer the utter solidity of a solid surface, and I further prefer NOT attempting to bludgeon my vise off from my bench using a large (lead loaded, no less) mallet, which is the effect (if not the intention) of the illustrated approach.
Perhaps I'm over protective of my tools. But that's my preferance.
YMMV.
BugBear
(*) As an aside it's very helpful when gripping something like a bowl blank.
>No argument, Paul....but many folks who have to chop these work in boatyards without a good bench.
That temporary bench my vise is affixed to was built into the wall of a temporary shop...all done in the rain of winter. The boards have shrunk and cupped and the bench just ain't flat enuf for that.
Charles
>Instead of posting 'continuation' threads could you simply provide a link to your website where we could browse your many articles?
>This is my website and Ellis and Garrett post them for me in the articles section over time.
These are chapters in a book I'm preparing for my kids and grandkids...the forums are just a way to get feedback for clarity revisions....thanks for that, but I've no need of a website.
Charles
>You ought to consider it. No offense intended.
Good point...
Scott Burr in Ben Lomond CA
>You had to go to counceling as a child too? What do you see in this ink blot;).
Kidding aside... About metal vices and holding work compaired to wooden vices.
Scott who sometines uses a wood screw clamp to keep from cracking/blowing out Morti in thin wood. It's seems reansonalbe to use a modern vice for this application.
Mike L
>Thank you for yet another great article Bob. One thing that is difficult to gauge from the photographs is the force used when striking the mallet (which seems relevant to the tangent at hand). The mallet in your photo doesn't seem capable of delivering a large force to the end of the chisel, leading me to believe that, strong blows (and hence an extra-sturdy bench support) are not necessarily required. Am I looking at this correctly?
Cheers,
Mike
btw: You _do_ know don't you that somebody out there reading this is thinking "gee, I can cut tenons with a Unisaw equipped with a tenon jig and I can make mortises with a dedicated hollow chisel mortiser so why is this Smalser guy wasting our time with this handtool stuff?" (wink)
Dan Donaldson
>Bob says in the article that the mallet is lead weighted and weighs over 2 pounds ;-) That would probably hit pretty good. It would be easy to miss that in a first read.
Mike L
>D'oh! I gotta learn to read while I look at the pretty pictures. Thanks for pointing that out Dan.
Cheers,
Mike
'Course I Do...
>"You _do_ know don't you that somebody out there reading this is thinking "gee, I can cut tenons with a Unisaw equipped with a tenon jig and I can make mortises with a dedicated hollow chisel mortiser so why is this Smalser guy wasting our time with this handtool stuff?" (wink) "
Of course I do....and 25 years ago I cut thousands of mortises on big, honking 3-phase Powermatic overarm mortisers long before benchtop homeowner models came out.
Those mortisers were finicky, expensive pains in the butt, given enough use. Get two or three sets of the best bits you can buy and find a good sharpening service, as too much pressure on that lever will permanently ruin their alignment, making them even more finicky.
Why bother if you are a hobbyist making heirloom one-offs or boats with a limited tool and wood budget? On one-offs at a commercial pace, my standard for hand-chopping versus the router and jig or booking time on the over-used mortiser used to be 12 mortises using expensive laminated Japanese mortise chisels. Now that I've scrounged these better millwright chisels, that standard has increased to 16 mortises and the Japanese chisels were sold.
Jim in Burlington Ont.
Jim in Burlington Ontario
>Bob another great how to. I could really envision a book of how to video's in this day and age. Thanks for posting and keep'em cummin. Jim
Q&A - Mortise
>Q&A - Mortise
[quote] If the workpiece is held solely by friction in the jaws, this places a lot of stress on the vise and its fixing to the bench. Even if a spacer is placed below the workpiece so it site directly on the guides and/or screw, it's needless. Much better morticing work holding is had by placing the workpiece on the bench top. If your bench is truly massive, anywhere will do. If your bench is a little lighter, over a leg is the best.
To hold the workpiece, you can either clamp a piece of scrap DOWN on the workbench, and then clamp the workpiece horizontally to the scrap. Proper 'G' (AKA 'C') clamps are best for this, since the shock of chopping tends to make 'F' clamps lose their grip.
Alternatively clamp a hand screw to the workbench, and hold the workpiece in that, In either case, a wonderfully solid support is obtained. If you really do a lot of morticing, you might consider a dedicated morticing stool/bench. [/quote]
[quote]Very interesting. I'll have to try chopping in the vise, which I have avoided due to early teaching. I have a Record made into end vise with 4th pair of wooden (this time beach) jaws just installed and I hope I can apply enough pressure. I have tried holding the piece to be chopped with a holdall but it tends to slide along the bench top and that leads to all kinds of contraptions.
I have a continuing problem with the chips if the mortice is short and narrow, especially as I get deeper. So far the best solution has been to use a narrower chisel to pry them out but it's not very efficient. I'd be interested to know your solution.[/quote]
Great input and thanks. But just put a spacer block in the vise so the force is directed to the rails instead of the jaws of your vise and you won�t hurt anything. Most of the folks I target don�t own a good bench yet�nor do boatbuilders working out of a tent. I always figured the old adage about not banging on the vise dated from the days of wooden threads and rails.
Again....don't worry about the vise....an old patternmaker I used to know, who used a his big Emmert for everything including tasks I have a 20-ton press for, would chuckle at concerns about using a wood mallet on one.
[quote] I love Arts and Craft style furniture so I have a lot of mortise and tenon cutting in my future. I don't doubt your expertise but being new to this I learn from reading and then trying to do what I've read. When I read things that appear to contradict each other then I question why and which source is right.
I read that the tenon should be at least 1/2 the area of the end grain on the rail and should extend 2/3 of the way into the post. If my math is correct (never was my best subject) then your tenon should be 1 & 1/2 by 5/8 not the sizes you listed.
Is there a reason why your is different? Was what I read wrong? Has experience taught you otherwise?[/quote]
Nothing wrong with your rule of thumb�it�s just not near as critical as some make it out to be, IMO. The joint is so incredibly strong that a little bit here or there isn't important...especially in larger scantling sizes. That rail would break in the center long before either your or my joint failed....and take too much out of the post and it'll simply break there, instead, if it's dropped off of the loft.
A one-inch wide mortise would be comparably fragile in the mortise cheeks for those drawbore pins, though.... and 7/8 would be the widest I'd go.
Two reasons for the size I chose:
1) It's a short assembly table.... I want some meat left on the outside of the posts to later dado in a shelf if I need one.
2) My 7/8" mortise chisel isn't as photogenic as that lovely 3/4" Swan.
[quote]You _do_ know don't you that somebody out there reading this is thinking "gee, I can cut tenons with a Unisaw equipped with a tenon jig and I can make mortises with a dedicated hollow chisel mortiser so why is this Smalser guy wasting our time with this hand tool stuff?" (wink) [/quote]
Of course I do....as I inferred, I cut tenons primarily on the TS, too�and 25 years ago I cut thousands of mortises on big, honking 3-phase Powermatic overarm mortisers long before benchtop homeowner models came out.
Those mortisers were finicky, expensive pains in the butt, given enough use. Get two or three sets of the best bits you can buy, consider fabricating a stronger hold-down, and find a good sharpening service, as too much pressure on that lever will permanently ruin their alignment, making them even more finicky.
Why bother if you are a hobbyist making heirloom one-offs or boats with a limited tool and wood budget? On one-offs at a commercial pace, my standard for hand-chopping versus the router and jig or booking time on the over-used mortisers used to be 12 mortises using expensive laminated Japanese mortise chisels. Now that I've scrounged these better millwright chisels, that standard has increased to 16 mortises and the Japanese chisels were sold.
[quote] Have you posted an article on making the lead weighted mallet? [/quote]
No�just turn yourself a mallet, copying whatever one from a catalog or website you like......bore deeply into the end using your largest Forstner bit.......pour molten lead or wheel weights in there and let it cool...do it outdoors wearing a respirator�...hammer the shrunken lead tight using a punch......and fabricate a bung on the lathe to cover the hole with a contrasting wood.
This one is merely a hunk of Bigleaf Maple chainsawed from a large crotch with a Purpleheart bung.
Re: 'Course I Do...
Mike L
>Hi Bob,
I just wanted to make it clear that the addendum to my post was just a bit of poking fun at the fellow who complained about your intriguing salute to the incredibly versatile bit brace. Like most people who read this board, I think your posts are a real treat and I thank you for taking the time to make it easier for beginners like me to learn fundamental skills and techniques.
Cheers,
Mike
