Auction "wood block plane"
Dale Stansbery
>I finally found one of these things in the wild. The auctioneer called it a wood block plane. Bidding was furious at $1 a step, but I finally prevailed at $20.
It needs a little attention, and a new blade. Where would a person find a blade that's slightly tapered thickness and 3/16" thick at the bevel and 2 1/8" wide. My best guess is that it is a cast body, but I haven't attempted any cleaning yet. It also has a cast steel cap iron with the name cast in it as opposed to bronze. The tote is a replacement, and looks like beech.
Re: Auction "wood block plane"
For $20.00...
Scott Burr Ben Lomond,CA
>You Suck!
You have a newer Spires infill plane. Poor thing has seen better days though. Your lucky, there some splended posts about rehabing infills here. One thing for sure you'll need a new blade for it. It's going to need alot of TLC but for $20.00 and some of your winter you could have a nice plane.
Bob Hackett
>For $20!!!
Why,that`s quite a driveby gloat there.Hope you saved $5 to pick up that garage sale #1 on the ride home.
Does it glow in the dark?I hear those planes keep an edge longer.;^)
Mainely,Bob
PS-You suck!
>A little rough, but certainly well worth $20!
If by "cap iron" you meant "lever cap" - the pix show a little green on it. Are you sure that it is not brass underneath the crud?
Have fun cleaning it up, and be sure to show us the "after" pix.
Oh, and YOU SUCK.
Congrats
David Miller from Iowa
>Very good value. You probably already know, but super fettler Bob Smalser has posted some awesome threads on putting these things right.
joel
>Congrats.
But the blade should not be tapered (only wedged planes had tapered irons) and you should get it made last. THe reason is that once the entire plane is back in good shape you can then measure the mouth and get a blade ground up to exactly the right thickness for the mouth thickness you need. And it's not particualarly expensive to do - Ray Iles for one does this all the time.
Re: excellent previous posting
paul womack
>restoration thread by Woodburn Bob
BugBear
Ernie Miller Topeka
>That is the uglest POS I have ever seen! and I collect junk. I would be ashamed to have bought somthing like that. But on the other hand it's only twenty bucks and we all have to learn some where. I agree you suck!
