Introduction and Blade Flattening question
Jake J. (Windsor, Ontario)
>Hi All,
I am beginner woodworker and want to start by building a 'Bob Key' type work bench focusing on hand tool work instead of power tools. I've been reading this forum for a while now, and I've learned that dull tools are useless so I've been attempting to sharpen anything I can get my hands on, mostly older stuff that is pretty beaten up(chisels mostly, a few plane blades). I've obtained a few new tools (gifts mostly) as follows:
4 Bevel edge chisels
1 Mortise chisel
3 old stanley planes (users, not collectors)
But I'm wary of sharpening them just yet. I'm having a tough time with a repeatable(or at least once) technique to flatten the back of these things? I have tried flattening the old tools and I always end up rounding the sides/edges (On the bright side, I seem to be able, to get a sharp cutting edge, but not very consistently).
I've tried using sand paper on plate glass and it seemed promising until I got to some of the high grits, that's when the rounded over edges showed up. My technique is to simply lay about 1" to 1 1/2" of the back of blade on the paper and either skew it slightly or hold it straight and move it back and forth with moderate pressure(I normaly press on things too hard, so this may be one problem) until I see a consistent scratch pattern. With the sand paper I used alot of grits (80, 100, 120, 150, 180, 220, 320, 400, 600, 1500, 2500) and the rounded edges showed up at about 400 or 600 and did not go away.
Then I tried using a 1000/4000 grit combination waterstone (Which I cannot seem to keep flat either), the 1000 grit looked OK, then the 4000 side showed the rounded over edges. It's got to be something with my (lack of) technique, or I'm simply missing an important step.
I also have some used norton oil combination stones, that I've never used (they are probably not flat either and I'm not sure of their grit size).
Some advice would be helpful.
Jake.
