Two or four stretchers?
Bob Rozaieski
>I have finished and dry fit the trestle assemblies of the new bench, all 3" square. Last night I dressed and laminated up some stock for the front and back stretchers. They are going to be about 5" wide, about 4" from the floor.
After finishing up for the night I checked out the bench in the 2003/2004 Tools & Shops (The Essential Workbench) because the base of this bench is very similar to mine. I got a little worried as the author used four 4" stretchers, two high and two low, front and back.
Will I have problems with racking if I omit the top stretchers? The Ulmias and Diefenbachs don't seem to have two front and back, but it looks like they use a wider (maybe 8"?) stretcher front and back closer to the middle of the base assembly (my current Bob Key bench has this). I wanted to leave additional space for a board jack and stretch the lumber I have. If I make two more stretchers I'll come up short on lumber for the 3" top and 5" aprons (I'm using what I had available) and I'll only have about 13" for a board jack between stretchers. Can I go without the upper stretchers or should I just suck it up and get some additional lumber?
Thanks for your opinions as always!
Bob
