Sharpening..anybody use paper wheels??
John Longwitz-Doraville, GA
>I got a pair of 8" X 1" pressed paper wheels about 10 years ago at a gun show. Use grit on one wheel and white polishing compound on the other on my grinder. Puts a razor edge on all my knives in no time. Just curious as to why I haven't seen them mentioned on any of the sharpening threads. I see that Woodcraft sells them also. I am trying other methods with my woodworking tools but may wind up putting the final edge on with this system.
Re: Sharpening..anybody use paper wheels??
Dale Lenz, Tahlequah, OK
>Hi John,
I've been using 3/4" paper wheels for 10+ years myself. I was amazed on how fast it puts a hair shaving edge on my tools, 30-45 seconds. A few months ago I made some shooting boards for my planes and could not get a square edge on my stock. After investigating, all of my plane irons are concaved. I squared them up on the belt sander and went back to the paper wheel using my Veritas grinding thingy. I was making concaved edge again. Sadly, I have gone back to my water stones. On the bright side, I can shoot a full curl and square now. I will keep the paper wheel and the dedicated grinder for things that don't need a perfectly square edge; such has pocketknives and such. Anyway, that has been my experience.......Dale
SteveC
>The ones I have used require me to hold the tool with the edge away from the rotation of the wheel as opposed to regular wheels where the blade goes into the wheel. It means all my jigs and holders are wrong and I haven't been able to hand hold my blades steady enough to get a good square edge consistently. I have gone back to a combination of diamond stones and scary sharp.
>I mounted my grinder backwards to the bench, then used the jigs....Dale
SteveC
>Yes, but then I'd have to remove the guards on the wheels, lose dust collection, the switch would be in the wrong position for safe operation and on and on... Too much trouble for what I saw as little gain and that available through other methods.
Re: carvers
paul womack
>I think abrasive loaded wheels are pretty much standard for carving.
Carvers don't have to worry about flat backs (bench chisels) and straight edges (plane blades), on their funny shaped tools.
BugBear
