Superiority of Neander Method
Jay Samuels
>I don't often feel moved to submit a post, but . . .
I am putting in prefinished oak strip flooring. I bought one room's worth and finished with 2 boxes left over. Then I bought for the hall and the next room, and came up one box short. No big deal, except the first batch is just slightly but noticeably thicker than the second batch, and has a different placement of the tongue and groove.
Plan A was to take a couple light passes on the jointer (I bought a vintage Delta last year, have never used it). The first test piece convinced me that was a real bad idea. So I bought an LN scrub plane (Force Machinery, Route 22, Union, N.J. - no affiliation). What a great tool. I took a couple passes with the scrub plane and then smoothed out the bottom with a Four Square (gasp!) 5 1/4. (BTW, the casting is identical to a Bailey 5 1/4, except for the frog screw and the little raised piece to help hold the tote).
Then for the transition row between the old and new flooring, I has to glue a strip into the groove and rout a new groove in the configuration of the old flooring. I'm sorry to report that I did not have the patience to try and do this with a 50.
Re: Superiority of Neander Method
>sounds like a great handtool experiance to me Jay, plus you got a new toy out of the deal! :~) Isn't that LN scrub just a beauty. Works as good as it looks.
Don't feel badly about not using the #50 ya' done well none-the-less. you should post this on the Noisy side as well.
Todd O.
