Clearing a clogged lead screw
Jonathan Peck - N.Y.
>Not to long ago someone asked of the group to recommend a favorite book selection. Well, here's one of mine - Anything you can find written by Aldren Watson. Everytime I flip through Hand Tools Their Ways and Workings, I can't help but find some practical, yet so simple I should have thought of it tip to make woodworking easier.
Clearing a lead screw
"When the screw does get clogged - as it will many times - it must be cleared before working it again. The thumbnail does the job fine, but if you don't like working that close to the sharp flukes, use a chip of wood or, better still, a modified spring clothespin. Set the clothespin jaws in the screw thread next to the cutting lips and flukes. Pinch the clothespin between thumb and finger, then turn the bit backward, or counterclockwise. This should strip out all the wood. Don't under any circumstances use a nail, knife, file, or anything metal - it will dull the screw threads." Aldren watson
The illustration shows to cut off the rounded tip, leaving sharp pincerlike jaws.
