Finish for plane rack question.
Matt Malin
>The wood that will surroung the planes needs what sort of finish? Oil-based? Is water-based ok?
Matt Malin
Re: Finish for plane rack question.
Ernie Miller Topeka
>Mine is unfinished but I'm lazy some day it will be BLO. I think any thing will work because the planes won't be on it untill it is dry.
Scott in Douglassville, PA
>I used milk paint and Minwax tung oil finish. The red milk paint goes nicely with the black gas springs. Hee hee hee
deanj
>I'm not sure if there is any historical reference -- But how about no finish? Don't we want the wood to act as a moisture buffer and adsorb what it can? And a finsih only hinders that process?
Adam, is there any evidence of that line of thought?
-Dean
deanj
>Oops, I was thinking of a tool BOX, not a rack.... Nevermind....
I just had a thought...
Matt Malin
>If I properly oil my planes and keep them clean with routine maintenance. It may not matter if the wood is finished or not.
Gary in Vancouver, BC
>I just finished a cabinet for my planes recently. The design is such that the planes sit on a level shelve (yes, with blade edges potentially touching the shelve - ooohhh! )
I reasoned that a pure tung oil finish was the way to go instead of a surface film finish, since its easy to touch up the finish when scratches and scuffs occur. I don't believe there is a moisture "trap" situation that occurs from resting the sole of the plane on a shelve. Just my opinion.
Milk Paint & Tung Oil?
>Scott,
I have never used milk paint. Why does one put tung oil on top of it?
Re: Milk Paint & Tung Oil?
>Hi, Don -
Milk paint, while pert near indestructible on it's own, is incredibly sucseptible to water stains if left unfinished. Think there are two main schools of thought - finish with some kind of wax, or finish with some kind of oil/varnish. Acrylic clearcoats also have their advocates. Guess that's three schools. Oh well. The color of the paint darkens a bit, and becomes a little more homogeneous, a little more water/stain resistant, and a little less chalky.
For my plane rack, I finished the milk paint with Minwax tung oil finish (which is an oil/varnish blend), and the walnut dividers got the Minwax finish straight. Aside from needing a good dusting, the finish has held up fine.
Sheeeeeessshhhhh!
Scott Burr in Ben Lomond CA
>What a blatant biased gloat!...Again!
Rock on dude.;)
>Aha. Thanks, I also did not know that MinWax Tung has some varnish resins in it. I imagine that makes it a bit more water/alcohol resistant.
Thanks.
