45 blades work in a 50?
Ernie Miller Topeka
>Will 45 blades work in a #50 plane? I'm thinking about picking one up missing the blades and wonder if the blades I have will work.
Re: 45 blades work in a 50?
Re: no...
paul womack
>Not with Record models, certainly. The depth adjuster notches are on opposite sides in these 2 models.
BugBear
Yes
jim_reed@marietta
>How well they work depends on what model of #50 you use. Early models clamp blades from the sides and all #45 blades work well (except for the 1/8" which is too short to clamp, and those over 1" which are too wide to clamp). Newer models of the #50 have an adjusting lever which uses grooves on the back of the blades. You can remove the adjuster with a screwdriver and use groove-less blades from a #45.
