mixing oil and water stones
mike morris
>Hi,
Does anyone mix oil and water stones in their sharpening routine?
I have been using Arkansas stones for several years, I think successfully, but after a recent guild meeting in which sharpening was discussed I am reconsidering my methods.
Adding water stones (Shaptons were recommended) to my kit makes sense, however I am disinclined to totally abandon perfectly usable oil stones.
Currently I finish up on what I think is either a black or surgical Arkansas (bought at a flea market, is black, and quite old)
If I were to add some combination of 2k, 3k, or 5k grit Shapton would that make sense? Is there some reason to use one system or the other??
Would wiping the blades well between oil and water stones protect the water stones from contamination?
Most likely only planes would ever see the Shaptons, I don't know that the difference with chisels would be worth the time.
Mike
