So, tell us Andrew (Pallas)
>Choosing and buying the bench will be restricted to internet or mail order as I live on the remote west coast of Scotland.
I really don't understand this statement. what does your location have to do with the option of building your own bench?
I "built" two benches myself. By built, I mean something that I intentionally set out to build a workbench and not just some plwoood between saw horses. Actually that is a bit of a lie, as I've only built one base, but it has had two tops. The first top was two sheets of 3/4" plywood, which while adequate as a work surface, I quickly out grew. the second top is made fir 2x4's on edge that I glued and bolted together. I made a shoulder vise, and a tail vise from off the shelf hardware such as threaded rod, nuts and washers. Works very well, I like it allot, and it cost me almost nothing. :~)
My point is, as what others have said is to go this route. Start off simple, get to WW, and you'll soon know what it is that you desire in a workbench. I'm sure that you could build your ouw as well. Lets face it, ordered workbenches are expensive, and they aren't nothing more than you yourself could fabricate and customize TO YOURSELF. Nobody will be able to do that better than YOU. With a little scrounging in the trash bins and what know you should be able to come up all the wood you'd need and perhaps even some of the hardware.
I highly recommend this idea, and with the saved $$$ you can buy some more tools. :~)
What have you decided to do?
Todd O.
