Show and Tell -- Revisited *More PICS*
WoodburnBob
>You thought I was done. So did I. Thought I'd get back on track. Re-honed the blade. Cinched down the lever cap. Inserted the blade/cutter assembly. Felt a little wobble/rock on the bed. Ignored it. Started planing. Shit! Put my thinking cap back on...which you can see is more dangerous than it seems.
Here are new results. Friday's results. Saturday's results may differ.
Recall I accepted the premise the iron was flat. Surface plates tell no lies. Correct?
I checked flatness with the cap iron off!. Cinched down, it turns out everything is a completely different story. Clamping on the cap iron puts a 0.010" (at least) bend in the iron. If there were no twist, so what. It simply lifts the middle section of the iron off the bed...where I presumed my dreaded mound/lump/bump was anyway. It does sort of negate the idea that infills are superior because the iron is clamped tight to vibration dampening rosewood, though...doesn't it.
So if I remove the cap iron, I can't pass even a 0.0015" feeler gauge between my trusty Starrett straight edge and the blade.
This doesn't yet explain the original rock/wobble of iron on bed, you say. Here's a nice V-block. Very accurate.
I set the iron (no cap iron) on the V-block and it's a perfect mating. No rock. No wobble.
I set the iron on it with cap iron tightened and what do you know. The assembly has the same rock/wobble as putting the assembly on the infill bed. In fact, I can measure it with the feeler gauge. What do you know, 0.010".
So putting the cap iron on does two things: bends the iron and puts a twist in it. I occurred to me to inspect the cap iron (he says, knowing full well the audience is way ahead of him). Yup, there's that 0.010" twist again.
Yup. There it is again.
Well, I do remember filing and sanding that hook. Trouble is I must have totally f**ked it up originally and was completely oblivious to what I'd done.
Yup, no rock or wobble here. The cap iron is flat enough.
Fixing things...fixing things should be a remarkable statement coming from my lips...anyway...trying to undo my damage to this cap iron doesn't immediately strike me as a trivial operation and I'm going to think about it a little. Yes, I understand the danger.
It is humbling to think that I could delude myself for some many hours in a row and then publish it on the internet as if I were the great infill tuner from the mount. If anyone is in any doubt that I am actually the local court jester, this should set you straight.
