200+ woodworking book reviews
Finishing Woodsmith Plane Kit *LINK*
Matt Malin
>In the directions for the kit it says to put an oil finish on the wood. I have the brass attached is it ok to put the oil on over the brass? Or should I take the brass off and finish it?
Woodsmith Kit
Re: Finishing Woodsmith Plane Kit *LINK*
paul womack
>I'd just oil the plane, and repolish the brass afterwards. If you've got that plane tuned and workin' I would NOT NOT NOT take it apart.
BugBear
Finish on the sole?
Matt Malin
>I hadn't flattened the sole yet because I was thinking that I would have to remove the finish from the bottom anyway(if messy)...But, should I flatten the bottom and then finish it leaving the finish on the bottom? Then rub some wax onto the finish on the sole?
Re: Finish on the sole?
David Miller from Iowa
>When you say "finish" on the brass, is it the oil you put on or is it lacquered? In any case, I'd oil it up good, then get some solvent and clean off the brass.
Go for it and be sure to post a picture.
Will do on the pic.
Matt Malin from Central Iowa
>I got a little aggressive with the stationary belt sander so the the front is not as rounded and full as the plane in the linked ad. I got it on clearance for $30 and the Hock blade and 'ingot' weight chip breaker, that were included, were worth that!
Re: Will do on the pic.
>Don't worry about your "excesses" with the shaping. The original looks like it could use some refinement, both in the ergonomics and aesthetics departments. OTOH, it looks like a fun project.
