1ST ATTEMPT AT PLANE REHAB
Gerry Doll
>Following the advise of the galoots on this board, started inquiring of friends re: old tools. A colleague submitted a #6 of his father's (either the devil's jack plane, per Sir Patrick, or a Nancy boys joiner per the archive)
Pretty grunged up, surface rust, but sole appears flat and square to the sides. Used Simple Green to clean grunge, and Naval jelly to get rust off iron and chip breaker. (May need to order replacement from the Eminent Sr. Hock) Have had excellent result using automotive valve lapping compound (120 and 280 grit) on surface where frog meets casting.
About 80 of original finish remains on base. On areas where it has flaked and peeled away, surface rust. Will attempt to remove with brass brush. This is to be a user, as I am lacking a joiner.
???? After removing rust from top of casting, next step? Oil it? WD40? Spot paint paint bare areas with Rustoleum??? Polish with the untainted blood of vestal virgins?
Appreciate any assistance.
Gerry
P.S. Kudos to Bugbear for the info and links on his site re: Plane restoration.
