St. James Bay Plane Kits
Gene D. in Pa.
>Has anyone tried one of their "Rough Casting" Kits? and if so,How much machining is required? Are we talking some filing and polishing or will I need a fully equipped machine shop?
Also, how do they compare with Shepherd kits?
Any feedback to assist in my purchase descision would be appreciated. Thanks in advance,
Gene D
Re: St. James Bay Plane Kits
David Miller from Iowa
>I got the rough casting kit for smoother a number of years ago - it's just a rough casting - like it says - you have to machine all surfaces. Mine turned out OK (not great, but that was me and not the kit) it just took me a long time and some chits with my machine shop buddies.
Can't say about the Shepard, but unless one is handy with metalworking and has some grinding equipment, I'd go with the "almost finished" kit.
Gene D. in Pa.
>Thanks for the reply David, If I go with the St.James Bay, I'll go with the "almost finished".The Price seems very reasonable. I've read several positive posts here about the Shepherd,but didn't recall many bout the St.James.
Tried an archive search couldn't find anything relevent.As far as performance comparison between Shepherd/St James,might have to get one of each and do my own research.(thats it, Ill explain to the Mrs.I have to do a report for you folks)Ha,ha
Thanks and Happy Wood Working,
Gene D.
Paul Warnock
>I have bought two of their machined castings and am very pleased with them both. I first bought one of the smoother kits (machined casting, blade, etc. It is the #51 style with a 55 degree bedding angle. I use it regularly as my go to smoother. Last year I bought a #11 style mitre plane casting, but asked Bob (the owner) to machine the bed for a 15 degree angle. After adding my African blackwood infill, it weighs almost 7 lbs. the weight makes the plane shoot very easily. I can't say enough about both planes. Only tools I used were a drill press, a dremel and files. If I can be of further help, just let me know.
Don Thompson, Cutler Ridge, Florida
>If you have any further questions or doubts about the SJBT kits, I would encourage you to call and speak to Bob, the owner. He has been very helpful with my purchases from them. He did discourage me from getting one of the kits (IIRC, it was the thumb plane), saying that it would be hard to complete without some sort of machining setup. Note that this does not apply to all of their kits.
NB: Shipments can sometimes be a bit slow.
