REAL MILK PAINT
Lacquer on all chisels?
Marcus D
>I have a set of Sorby mortising chisels. I'm trying to sharpen them in preparation for use. All of my instructions (including most on this board) suggest removing any lacquer from the tools. I'm not sure whether or not the tool actually has lacquer on the surface. Should I assume that it has lacquer and try "removing" some of it? Is there some telltale way to determine if a tool is covered in lacquer or not. It looks perfectly usable to me. Thanks.
Re: Lacquer on all chisels?
John, NY
>There was no laquer on my Sorby's when I purchased them.
Alan Hamilton
>Marquis,
To test them, let one of them spend the night with the steel in lacquer thinner. If it's lacquered, the coating will slough off the next morning. If it's not lacquered there's no harm done.
I knew my Hirsch chisels were lacquered before they arrived. I tried letting my 800 grit waterstone remove the lacquer during the sharpening process. Big mistake. It would take forever doing it that way; and it gummed up the stone a bit. I stuck all the chisels into an old mayonaise jar, without the mayonaise of course, with enough lacquer thinner to cover all the steel, and the next morning all the lacquer came off easily with the help of a little steel wool.
Alan
Mike Lietzow
>Hi Marcus,
In his DVD on Sharpening, Leonard Lee suggests scraping the laquer off using the cutting edge of a chisel. It's kinda funny because first he says something like "using a sharp chisel for this would be an affront to all that is decent in this world" so he uses a dull Bluechip; which doesn't work so swell so he says "maybe using a sharp chisel would work better" or something like that. On second thought, I'd try the laquer-thinner method first. :-)
Cheers,
Mike
Sean Evoy
>Card scrapers work well, too. It may not be the most gratifying ten minutes of your life, but you avoid the fumes and having to wait overnight with the thinner approach. Anyway, it works for me and spares one of my chisels the indignation :-)
