A55 Smoothing Plane
Closet Organizer is Complete!! *LINK*
Dan Clermont in Burnaby
>Even though this Closet Organzer is quite "Boxy" and lacks in styleI thought I'd post some pics.
The Closet Organizer was dimensioned with a ECE scrub plane, transitional jack plane (sub-scrub), Bedrock 607 followed up with a Bedrock 604 1/2 and LN low angle jack (york pitch blade on the Low angle jack) and then a Veritas Cabinet Scraper (which failed miserably), Bahco Cabinet scraper followerd by 220 grit.
This project was supposed to take a couple of weeks but ended up taking the better part of a year cause I got sick for a month, my son was born, FIL daiagnosed with cancer, FIL passed away and life finally got back on track.
The dimensioning took allot longer then expected and the original boards were 6/4 taken down to 3/4. The joinery was a combination of a *le*tr*c router and handtools (LN 98/99 for the dado's) and LN 60 1/2R for the Sliding Dovetail. The top was dovetailed to the sides and the closet organizer was too tall for my shop so it had to be storedon its side in m shop and the dovetails were cut whil standing on my kids "slide" set seen in the background.
The project was finished with 3 coats of Watco Danish Oil and Johnson's wax. Epoxy Inlays were used on some of the voids in the knots.
Sideview
Re: Closet Organizer is Complete!! *LINK*
Sliding Dovetail *LINK*
>The sliding dovetail female was cut using *lectrons and the male part was done with a LN 60 1/2R Rebate plane set on a fence followed up with a chisel to make the groove.
The joint wasn;t as tight as I would have liked but paractice makes perfect and it works!
Sliding Dovetail
Dovetails *LINK*
>THe closet Organizer is about 7 feet tall and the only easy way to cut the dovetails was to clamp the tall boards to my kids "Slide" set. It worked quite well
Dovetails
Steve Kubien
Re: Sliding Dovetail
Steve Kubien
>The sliding DT's look pretty good to me. I've only ever cut them with a screaming routah but they didn't come out that nice. I'll be taking advantage of a recent artile/post about sliding DT's soon as my growing collection or woodies needs a permanent home. I'm going to arrange them vertically and the divider boards will look best if dovetailed, IMO.
Nice piece of work Dan.
Steve Kubien
Ajax, Ontario (a suburb of Toronto which all Canadians realize IS the centre of the universe. :} )
Re: Dovetails
Scott Burr in Ben Lomond CA
>Looks good Dan. Is the wood pine? Are the DT tapered? Now all you need to do is install it. I need to learn how to do these myself.
Jim in Burlington Ont.
Beauty eh!
Jim in Burlington Ontario
>Dan I have always loved the grain around knot's. Nice job.
Frank D. in Montreal
>Nice work Dan,
Looks good to me. I really like the wood too! The two sides closest to the camera seem to be resawn from the same board; that looks really cool.
BTW, how did you find the low-angle jack with the high-angle blade, compared to your 4 1/2? Was there less tearout? That swirly grain around the knots must have been tough to plane.
Thanks for posting!
Frank
Re: Dovetails
>Hi Scott,
The wood is a Western Maple and although theWestern Maple is known to be quite soft this stuff was quite hard. The top two drawer bottoms are also Western Maple and were quite easy to dimension with handtools.
The dovetails aren;t tapered. I am quite challenged when it comes to sliding dovetails so I went the easy way.
>Hi Frank,
I have the Bedrock 604 1/2 with a LN Chipbreaker and an Anton Berg Swedish Steel blade. I sharpen that plane with a 5 degree back bevel so it is essentially york pitch and to be honest the LN and Bedrock seemed to leave the same surface although the LN low angle jack was much easier to push around the knots. The Bedrock is a shorter plane so it was able to get into the tearout quicker then the LN LA jack.
I am thinking about trying out a LN 4 1/2 so I may sell the Bedrock someday but it all depends if the York pich LN is an improvement.
Dan Clermont
