Workshop opinions please (long)
Mike Lietzow
>Hi all,
My project this weekend is to set up my new shop (actually it's a (mostly) enclosed stall of a garage). If I could get some feedback from the collective wisdom of the HandTools forum, I'd really appreciate it. I tried to make a crude drawing in ASCII but none of the spaces were maintained in the "preview" so I guess you'll have to go on my poor descriptions alone.
First item is the position of my workbench. The bench is a pretty simple design: retangular with a standard face vise on one end and the small Record quick release vise used as an end vise at the other end. I was thinking of putting the bench perpendicular to a wall with the face vise end as close to the wall as possible. Since the vise is at the end of the bench (can't easily reposition it either), how close to the wall do you think I can put the bench without causing too much interference with typical use? Btw, I'm not really sure what typical use will be yet.
Secondly, if I go with that plan, the bench will be parallel to some cabinets (with a countertop that will serve as assembly or multi-use space) such that my back will be to the cabinets while I'm working on the bench. The opposite side of the bench will be somewhat accessible although that may require moving some items (on wheels) out of the way. How much space do you think is the minimum comfortable space in front of the bench (i.e. between the bench and the cabinets/countertop). I'm thinking I can spare 40" and still have room for the other stuff that will occupy the rest of the shop's space. Does that sound about right? Too much? Too little?
A third item is that there is a recessed area on one wall that houses the water heater and furnace/fan unit. Do you think there is any increased risk of rusting/warping from putting a tool cabinet adjacent to that area or am I just being paranoid (I know, I may be paranoid regardless of the answer to that question).
Thanks a bunch for your input and have a good weekend.
Cheers,
Mike - who will probably make 5 iterations of shop arrangements before I'm satisfied
