Lubricating the Sole
eric in Maryland
>Hey All,
Another question: Learning to hand plane and just tried putting some wax on the sole -- this really reduces the friction. Question is whether wax is the best thing to use. Is there something better that lasts a bit longer ?
Cheers
Eric
Re: Lubricating the Sole
Jim in Burlington Ont.
Jim in Burlington Ontario
>Nope pure hard wax the harder the better.
eric in Maryland
>Jim,
For the moment I am using "Butcher's Paste wax" -- from your answer should I be using something like wax from an old candle ?
Cheers
Eric
>A good hard candle is what I use. Parrifin wax is perfect also. Just scribble a giant S on the sole. It sort of burnishes the work a little. As for your other question about refibing a old plane look in the articles section and have a look thru the archives there's loads of info.
Plane wick
Robin Frierson
>Kingshott used to have this plane wick, where he would take a pass over the wick to lubricate the sole of his plane as he worked. I think he used some type of oil, BLSO or mineral oil. I think some member here may have made one, didnt Pam make one?
I use parafin wax, just keep a block on the bench, and it helps a lot.
Dmitri
>How about Jonson's paste wax? I just started using it and it seems to work much better than without one, but I am not sure if it's a right wax to use.
Two choices that I know...
Scott Burr in Ben Lomond CA
>Wax or oil. For wax all I use is a parfin stick (just like mom use to top her canning jars with), a used up non-colored candle works well too. For oil you need to make an oil wick. Start off with a tuna or similar sized can. you can use oil wicks (think kersone heater wicks here), old towels or tee shirts and wet with thinned down BLO. Some like the wick better cause you just run it over the wick and keep on planing. I perfer the rest break I get by using wax.
Just use a candle stub Eric
Andrew F in Australia
>(caveat: Haven't read a lot of your responses here already - apologise if I'm duplicating response)
It probably lasts about 5 min of hard planing on a sticky, resinous timber and takes about 2 sec to replace.
All you do is just draw a squiggle onto the sole of the plane.
Cheers,
Andrew
Re: Just use a candle stub Eric
eric in Maryland
>Hey all,
Tried wax from a candle -- that did the trick -- thanks all
Cheers
Eric
Re: Plane wick
Don Thompson, Cutler Ridge, Florida
>In the video, Kingshott said it was linseed oil. He did not state whether it was boiled.
