Plane Iron and Chisel back flattening
Todd M
>Hi,
I've finally got my self set up with chisels and planes and now need to get them all sharpened.
I was wondering if there has been any summaries online of what folks believe are the best ways to flatten the backs of irons and chisels? Also, do you recommend doing the entire backs? Are there motorized options that give good results, like the Tormek, or Lee Valley machine? I'm not against waterstones or sandpaper on a flat surface either.
Thanks for your help.
Todd
Re: Plane Iron and Chisel back flattening
Wade Mackey
>Well, it's probably over kill, but I just flattened a couple of plane blades by slapping them on the surface grinder. Does a great job. If you know a machinist that can help you out that is the quickest way I've found. Otherwise, I usually go with a diamond plate to start and then work my way up with water stones.
Wade Mackey
Lancaster, PA
Jack Guzman from Maine
>Do a search of this forum. This subject has been covered many times.---Jack
