THE WOODRAT IS BACK!
Shaping compound curves - ideas?
Scott in Douglassville, PA
>Hey, everyone -
Crossposting again, tapping some handtool expertise: The bed legs I'm working on sweep in two directions:
(BTW, these are two views of the same two prototype legs, and the sweeps are intentionally different. I'm a slacker, but not that off...)
I'm wanting a 3/8" roundover on the edges. I can rout the straigth edges, but a router ain't gonna get it on the compound curves. Ideas? I've got a LV LA spokeshave, but in practicing with it, it seems slower than necessary (though this is likely my ineptitude shining through). Tried rasps and files, but couldn't get a clean curve.
Suggestions? Practice more? Help?
Scott
Re: Shaping compound curves - ideas?
joel
>get a cabinetmakers or pattermanker's rasp. It will do the job brilliantly and quickly but will take a little practice. pencil in guide lines to work more accurately.
deanj
>LV LA spokeshave which can convert from flat to curve bottom? That should do the trick.... It may go faster with a pair of std spokeshaves, one flat bottomed one curved, but the LV LA will work. Otherwise patternmakers rasp as mentioned...
Pencil in some reference marks and give it a try.
Bob Hackett
>For the final finish after the rasp and file work you might consider making a radiused scraper to even things up.
MB
>If you're willing to live with the radius you'll get, which is not 3/8", a concave shave does a nice consistent job of running a radius on a compound curve.
Frank Mutchler
>Scott, what about the Stanley #66 or the LN #66 with a blade ground to the radius you want? Seems to me it would do the job??
Success!
>Thanks everyone. Did some setup and fine tuning on the Lee Valley shave, practiced on some of the leg off cuts, and got some good results. Spokeshave, files, and a little sanding. Might try to find/make a radiused scraper, 'cause I hate to wreck the beautiful finish the shave leaves on the wood. Regardless, this is fun work.
Thanks for the input, everyone.
Scott
