200+ woodworking book reviews
Parts needed
Parts needed
Parts needed
Kurt Loup, Baton Rouge
>I'm in need of a thumb screw for the cap iron of a #12- like scraper. The scraper doesn't have any markings, but appears to be similar to a #12. I tried a couple screws in the cap, but the threads appear to be an odd size. I'm also in need of a blade for a Stanley 191 rabbet plane. Thanks.
Kurt
Re: Parts needed
Don't know if this will work...
Scott Burr in Ben Lomond CA
>Maybe a cal to Laurie at Stanley tools can help if a Stanley screw will work. Call her @ 1-800-262-2161 ext. 55839
If not you may beable to retap it to a standard screw size. Good luck!
Re: Parts needed
Retapping
>I've retapped for standard threads several times - usually works pretty well. If the cap is cast iron, you don't even need lubricant - the tap will work fine dry.
Re: Parts needed
Re: They have a few different ones
>Thanks,
I didn't see it listed on the webpage, but I sent them an email.
Kurt
Re: Parts needed
Re: Don't know if this will work...
>I called the number, but didn't speak to Laurie. No luck on the thumbscrew or blade. Thanks for the lead.
Kurt
Re: Parts needed
Re: Retapping
>I may have to go this route. Thanks.
Kurt
Re: Parts needed
John, NY
>You may want to call them. I didn't find them too responsive on the email.
