Mistory plane?
Mistory plane?
Mistory plane?
Terry Steinbach
>I found a Stanley plane at a garage sale. It seems to be about a #2 or #3. The frog is not adjustable. On the handle is Stanley Di Fience.
I want to know the exact model and waht it may be worth.
Re: Mistory plane?
Re: Mistory plane?
Ernie Miller Topeka
>Need more facts length width of cutter shape a picture will help there is a big differance between a #2 & #3 in price if it is a stanly defiance it is worth less than a bailey. $5-$500? with out more info. and that is beinng optimystic
Re: Mistory plane?
Re: Mistory plane?
Richard Gillespie
>Are you by any chance describing a plane where instead of a frog there are two vertical pieces of metal supporting the blade assembly. The depth adjuster is also connected to these two pillars.
If so, I believe that the plane is a Defiance, model 1244. They are not highly prised, are poor smothers because of the open, fixed blade to mouth position. I regrind the blade to an arc and use this type plane as a scrub plane.
