Hanging cabinet door ?
David E Whiting
>I just made a spice cabinet, after hanging the door,I noticed a 1/8 in gap on the right side and a zero gap on the hinge side. what should i do next to balance this?
Re: Hanging cabinet door ?
Wiley Horne--Glendora CA
>Hi David,
I've always imagined that cock-beading was invented to deal with problems of this nature (assuming it's a rectangular door). If there are two doors, you could use a false astragal on the other door, or else a real astragal between the doors.
Wiley......remembering all the times when it would have been faster and easier to just remake the door (or whatever).
RJ Whelan
>David .... playing cards make good shims - sounds like you need to move the door about 1/16th which should take about four layers (two behind each leaf ... rj
spice cabinets have unusual doors
Bill Tindall, E. TN
>How timely. I am taking a break from fitting 2 spice cabinet doors that are a tad too big.
The suggestions that have been made are not relevant to a typical spice cabinet door. Spice cabinet doors are applied on the hinge side and captured on the lock side, ie the door is not between the frame but on it on the hinge side. This way the door swings out of the way of the interior drawers. If this is the door arrangement you have, your only recourse on the hinge side is to plug the screw holes and slide the door over 1/16" thereby resulting in more hinge barrel reveal. If this looks bad (likely) then leave the hinge alone and glue a 1/16 strip to the lock side of the door. A good glue job will result in a near invisible fix. Unless the grain match is exceptionally terrible the thin strip will not show.
If you have a nontraditional door, ie it is captured between the frame, this discussion is irrelevant and shim the hinge mortise, but with something stiffer than paper. Saw a 1/16 shim. Or glue 1/16 on door .
does it matter what side hinge
davidewhiting
>If the door is inset, and if you used a hinge with the leaves in between the door and the frame, shim it by 1/16 inch. I would do this by shimming 1/32 inch on each hinge side. (I think)
Re: does it matter what side hinge
"RJ" Whelan
>David ... when I read your post I assumed this was an inset door; if not ignore this:
If you need to move the door away from the hinge side (because of a gap difference, or, because the door is hingebound you need to add material back to the area under the hinge leafs (I'm assuming the hinges are morticed.
The best, most aestetic way to do this is by adding a wooden shim under one or both leafs: this can get a little dodgy when you're trying to make a small move as the thickness of the shim almost guarantees splitting of the shim material.
Playing cards make good shim material because they do not compress except under extreme pressure (the material is highly compressed prior to coating).
The downside to shimming under the hinges is you may notice the fact that the hinge does not lie flush to the stile or door edge - the more you have to move the door the more noticeable the gap. This is why I recommended adding a shim (shims) under both leafs of each hinge.
The other suggestion about adding a thin strip of wood to the non-hinge side of the door will work as well. I have used this technique, but have had a few problems with grain matching (the strip becomes noticeable). I have found it easier to add a relatively thicker strip and then plane the door to fit.
Good luck ... rj
