Rust hunting How-to
Rust hunting How-to
Steve Kubien
Rust hunting How-to
Steve Kubien
>Hi everyone,
I am not a traditional rust-hunter. I don't tend to buy much that isn't ready to use after a bit of WD40 and light steel-wool. Rehabbing has never been my thing. I stopped by a garage sales last week and came away with few things which lead to a question.....
How do you know from the rust if the tool will be pitted or not? I picked up some pinch dogs (3 and 4" long), a socket chisel and a very aggressive file which I think and can use as a float. These were all sitting in plastic tubs, SUBMERGED in water. When I was done picking through things my hands looked like they'd been soaked in iodine!
They chisel is pretty pitted on the back and one side. The rest had at least as much flaky rust but came out looking really good (well, the dogs have some pitting but they are just pinch dogs so I'm not concerned). They file looked awful but came out very useable.
Any tips you veteran's of rust and rehab can offer? At what point do walk away from a tool?
Thanks for any advice.
Steve Kubien
Ajax, Ontario
remove the _9 to email
Re: Rust hunting How-to
Rust assessment
Bob Hackett
>I generally just use one of the tools as a scraper.Once you scrape the surface rust away any pits show up.
If you`re squeamish about picking up someone else`s tools and rubbing them together(why would they complain?how do you think they got that way?)then just buy the first beat up knife you see for a quarter and use it for a scraper.Remember to leave it in the car or you`ll be spending another quarter on the next trip.
Mainely,Bob
Ernie Miller Topeka
>That is a tough question rust is differant? if there is moveable parts check to see if they move if they don't walk or don't pay more than the parts are worth that you can get off. pitting usualy is only an issue on the back of plades and the sole of planes and the rust will look like it is deep. Then there is scale? how do you describe this stuff? it is rust from other soft metal that has caked onto the tool you are looking at. it will flake off some times leaving the tool looking quite nice. Scale is found on tools that have been in a bucket with other soft metal tools soaking for al long time wet-dry-wet-dry for years leaky barn roof bucket of tools. They will have nasty ass black wood. Every time you buy rust you are taking a chance. and no one around here gloats about there junk rust pile. NANNA NANNA NANnA I have more use less #4 castings than you. Kind of thing.
>Use the fact that is is badly rusted to your advantage. One thing I do is mention the hours it is going to take me clean this pile of rust up, and I sometimes throw in the idea that after several hours of work I might discover that it is broken as in the case of plane bodies, or that it is just to far gone to be saved. If you come across a plane that you feel good about, but it's rusty $3 seems to be the most settled on selling price in my experiance. I don't think anybody here can tell you at point to walk away as YOU are the biggest variable in the equasion. How badly do you want/need it? How much $$ do you have in your pocket that you are willing to spend at this very moment? I guess the best way to learn this is to just get out there and get to it, sure you'll get burned a few times, will make some stupid buys, etc, etc, but just consider them cheap lessons. It's really all in fun in the end Steve. Aslog as you're not spending the rent money, or taking food out of your family mouth just jump in the mix. you'll soon learn what is right, and what is not for you. Most of all just enjoy the whole experiance. I've made friends that I've made thru rust hunting that I wouldn't trade for a bucket full of #1's.
Todd O.
Todd Hughes
>Most times if the tool will have pitting the rust will be in spots that is heavier then other areas and that is where the pitting occurs, Even rust is often not that bad and can be rather fresh and can be cleaned OK,[maybe].Areas of pitting will look deeper of course.
Other then those with just surface rust that will clean off easly I think for most tools you are way ahead to not buy rusted stuff at least anything that needs drastic cleaning or on a related field have broken or missing parts. In the end you have a cleaned rusted or busted peice of junk and have spent more time and money it would have taken to get a nice clean tool.I really try not to buy stuff like this unless for parts, even if you get them "Cheap" it is a false econmy. Many tools are common enough that if you pass on it a another better example will come along.Of course on some things it is different, today I bought a rusty Chaplin patent plane a rather uncommon plane enough so that I bought it even if it's condition was a little worse then what I normaly buy,[I passed on a Stanley no. 3 in a simular condition]. I guess after a while you sort of devolope a sixth sence as to what to buy and what to pass on and what will clean and what wont'.....Todd
Steve Kubien
Thanks....
Steve Kubien
>for the advice everyone. How did I know I'd hear from an Ernie and a couple of Todd's? :)
As I said, I think the socket chisel can be saved but it will be a bit of work for the back. The bevel side will be easy with a hollow grind on the hand crank. Even if I get sick of the back (or it is too bad to make good) I think I will try my hand at making a handle for it. If I can get that right, a whole new world of old chisels will be opened up to me. I think it has been determined by our esteemed group that one can never have enough chisels (or saws, or planes, or braces.......)
Cheers,
Steve Kubien
Ajax, Ontario
Re: Thanks....
Ernie Miller Topeka
>Big slick? I wouldn't waist my time cleaning it unless you intend to use it. make your handle and sell it as it is. Let the end user do all the work. They are a specialty tool that most of us will not need. Let the collectors and boat builders have them. I have one large chisel that I use for timber framing but it is not a slick it is pounded on.
Steve Kubien
Re: Thanks....
Steve Kubien
>Ernie,
I'm not sure where I mentioned a slick. Nope, it is a generic 1" bench chisel. Nothing fancy.
Hey, if there is a makers mark under the pitting, where are they typically? I know that once the rust and pitting is gone the mark will probably be gone as well. Just curious for the future.
Cheers,
Steve Kubien
Re: high on Back, front or on the socket
Ernie Miller Topeka
Maker`s mark
Bob Hackett
>If it has one then it`ll most likely be on the blade just in front of the socket.Wilton and Greenlee(among other later makers)put thiers on the socket.I`d use either Scotchbrite or fine sandpaper to reveal the mark and keep the patina while taking off the rust.Most of the procedures for saw restoration work with chisels.
Mainely,Bob
Slick!!? Slick!!?
>Did somebody say Slick?! Where!? Who?!
Todd O.
