Gouge Till Shop Project with *PICS*
>[rant on] I hate chisel rolls! [rant off]
I find it very inconvenient to try to carve from a canvas chisel roll, because I can't see the shapes of the tools. Also, the rolls take up an immense amount of real estate when spread out on the workbench, and the sharp gouges quickly cut them to shreds. In the past, I had either been working directly out of my toolchest carving gouge drawers (as shown in the first photo) or with the required tools laying on the bench top. Working from the drawers, the tools were too far away to reach without bending over, too far away to see especially when using my close-up glasses for fine carving work, and the drawers filled up with chips. Working off the benchtop, the gouges, files and rasps seem to multiply like rabbits and fight tooth and claw, and still got buried under the chips.
I finally did something about it. I built this portable, modular carving tool till. When I'm carving, I open it up, unfold it on the benchtop, and populate it with whatever tools I need for the current job. It is in four fan-fold hinged sections. All the tools are in plain sight, easy to reach, and they don't bark and they don't bite. The latches keep it from being opened quite all the way, which makes it very difficult to tip over.
If I have to use the bench for something else while in the middle of a carving project, I can just close it up, latch it and set it aside with all the tools still in it.
When I'm done with the project, I put the tools back in the the toolchest drawers, fold up and latch the till, and hang it from a peg on the wall. I can also use it to carry a bunch of gouges over to the sharpening station.
The above pair of photos show the back view on the left and the front view on the right. A four section till needs three pairs of hinges and three latches. You can build yours with any number of frames, of any size you think you might find useful. For those who might want to build one, but avoid the effort to develop their own plans from scratch, here are some details of my prototype. When I built it, I didn't use any plans, so I've reverse engineered plans from the prototype. Mine is made of four through dovetailed frames. 5 1/4" high x 10" long x 2 1/2" deep.
I built them from some tulip poplar and a couple of pieces of mahogany scrap I had laying around.
The bottom piece of each frame is 10" long x 2 1/2" wide x 3/4" thick. Make 4.
The sides are 5 1/4" long x 2 1/2" wide x 1/2" thick. Make 8. You could even make the frames different heights, to accommodate different tools, but I found this one height handles just about anything I've tried to put in it. It is NOT big enough, in any of its dimensions, for a serious set of turning tools.
The top is 10" long x 2 1/2" wide x 1/4" thick. Make 4.
I laid out two different patterns of holes. The mahogany sided frame is sized to hold larger gouges, or three pairs of Wiss metal snips, if your craft leads you in that direction. I layout, cut and fit the dovetails, and then disassemble the frames, lay out and drill the holes in the top and bottom of each frame together. Laying out the hole pattern after cutting the dovetails keeps you from weakening the dovetails by getting the holes too close. Also, the top member could easily split while fitting dovetails if the holes were drilled first. The holes in the bottom frame are stopped about 1/2" deep.
Here are two full size patterns. I used 1/2", 3/4" and 1 1/8" Forstner bits to drill the flat bottomed holes. For the oblong holes, a chisel and a router are useful, or you could drill them all the way through, cut them out with a backsaw or coping saw, cut a rabbet in the bottom and glue in a patch.
When you lay out the hinge mortises and assemble it, the smaller holes in the upper pattern, which tend to hold shorter tools, should be positioned towards the front. Also, consider the tools you will be using from the oblong holes, and whether you are right or left handed. For convenience, you might want to flip the lower pattern over.
I built this till to complement the Carving Tool Set published last month in WC's Articles and Reviews.
Re: Gouge Till Shop Project with *PICS*
David Barnett
Wow! Thait is so very cool.
David Barnett
>Yeah, I gotta have one, and yeah, I wish I'd thought of it. Well done.
Nicely done! Thanks!
L. Hanson - N. Idaho
Jim in Burlington Ont.
Your the King
Jim in Burlington Ontario
>You are the king of carving acessories. I loved the carving bench and hold downs you made and that solutiion for chisels looks great. Thanks for posting Jim
Jorge Casta�eda ~ East Penobscot Bay
>William,
Nice solution, sometime down the line I will "borrow" your design.
Thanks for posting
Jorge
Don Thompson - South of Miami
>As usual, a novel and useful solution to a common problem. You are a great designer.
Once again very NICE.
CBT
>William, thanks for posting. I have gone back several times to look at your carving setup. I really want to build a carving bench like yours.
Your mallets almost make me want to learn to turn :) So far I have not been bitten by that bug.
CT
U Da MAN!
Scott Burr in Ben Lomond CA
>Very cool design and well executed Sr. William. Why do I have a sneaking suspicion we'll be seeing cheap plastic ones showing in WW stores and catalogs soon.
Can you say patent...
Re: we got a winner
>Looks great; probably would make a pretty nice FWW article.
Re: U Da MAN!
Rob Lee
>Actually - while this may be a new application, it's an old design...there used to be drill indexes made the same way.
Still - a clever solution, well executed!
Cheers -
Rob
well, " . . . necessity is a mother." nice!
John Truxell-Svenson (jvs)
I agree
Tom Sontag - St. Louis
>Just the sort of thing to win a chisel set with or whatever they are giving away these days. Nice job Sir Wm.
Re: U Da MAN!
>If you guys want to build and market one, or a whole line of them, go right ahead. I'd be flattered. I've no interest in patent rights or any such on it. I know that trying to identify any unique aspects would be more than difficult, even Swiss Cheese could be considered prior art or whateveryacallit. I suspect your design shop wouldn't use poplar, however, even ebonized. Maybe it was my judicious use of brass that attracted your attention? :^)
ChrisKnight
>William,
A great solution for a very tiresome problem and extremely timely as I have been racking my brains over the same problem and was tending toward an answer so much uglier than yours that it doesn't bear mentioning.
Chris
Re: U Da MAN!
Rob Lee
>Hi -
Nope - we won't do one - that's the kind of project that most people can work on, and make an end product best suited their own needs.
You have done a great job with it - and rightfully deserve the accolades you're getting for it! Just 'cause someone else had an equally good inspiration doesn't negate the fact that you thought of it independently too!
FYI - one of the ones I have is triangular... side 1 attaches to side 3 after unfolding, to make a fixed (and stable) triangle...
Cheers -
Rob
Re: we got a winner
>FWW? How many cordless drills and routers and brad nailers are you going to put in one of these? And, I didn't use biscuit joinery, either, even though that would have been more efficient and would sell more tools :^)
Note that I have built stuff for holding lots of router bits, but the difference is that you don't take much risk putting a router bit shank into a round hole, whatever you make the holder out of. Hand tools go in cutting edge first, so it is important to build it from a compliant material, like wood, maybe.
I think I like getting my articles published on Wood Central, but if Christopher Schwarz were interested, I might be pursuaded to work something up that was fit for paper.
Dale Stansbery
>William, that's an absolutely great design. For carrying it, I wonder if a back panel of thin plywood placed on one of the center sections, that extended above the handles and had finger holes in it would be useful. When it's closed, the panel handle would be in the center.
>That would be a great addition. I've also considered the possibility of building a permanent storage box, that opens vertically. like a portable bar, and hinging the racks to the inside or the outboard edges, so they could be swung out when the box was opened. I decided that idea is too complicated for my current needs, so I will save it for some future project.
Another idea that would be useful is dividers between some of the compartments, especially between rasps, which are all too easy to collide when taking them in and out.
Ha Ha!
>"Swiss Cheese could be considered prior art or whateveryacallit." LOL
That whateveryacallit is called intellectual property. Just so you know... yep, that's laywer talk.
Wayne Anderson
>Wow...that's very cool! Hope you don't mind if I steal the idea and adapt for files/rasps. Wayne Anderson
