Made an anvil...
Made an anvil...
Made an anvil...
Rob Brophy Niagara Falls ON
>Hey! I built a tool that isn't a plane!
I know it's not a woodworking tool but it was a pretty cool thing to build. We needed a stake anvil for a production of "Tinker's Wedding" this summer and didn't have much luck finding one that suited the set designer's taste. The SD supplied some reference photos & some rough measurements of anvils he liked in lieu of a scale drawing.
According to the designer's reference this style of anvil ( I think it's called a teeste) was used by travelling tinsmiths (or tinkers) and was driven into the ground or a log wherever he set up shop. I copied design features from several anvils, so I don't know if an identical anvil ever existed. Any further details would be appreciated. Guess I'd better order a copy of Anvils in America...I seem to be on yet another slippery slope.
The anvil body is 1 1/2" square thick wall tube, split on the bottom with patches welded in to create the flare. The horn was a length of 1-1/2" tube with a triangle section cut out and hammered into a cone on that nasty little anvil in the photo. The spoon was hammered out of some mild steel plate heated with a touch of oxy/acetylene.
When the anvil had cooled after welding, the beads were ground and the body was dimpled and textured with a ball pein hammer. The finish was achieved by heating with OA and brushing on a few coats of oil.
I'm sorta hoping that the actor is going to find it a little heavy to lug around in the production and will request one made from aluminum, and this one can come back to us. Once you get over it's odd shape, it's a very handy thing to have in the shop.
Re: Made an anvil...
Bob Hackett
>Rob,
Looks like what you have there is a rather tall bickern.As you said these were used by tinsmiths and other assorted sheetmetal tradesmen.They come in handy for small scale ironwork too.
Nice job(as always) putting that one together.Have you ever thought of taking up sculpture?
Mainely,Bob
>Hi Bob,
A bickern! Thanks! What are the usual dimensions for a bickern?
The designer was very specific with his dimensions. I suspect the blocking for the scene had already been determined and this height fit the actors position/posture. Prop builders are usually far removed from the talent and have to rely on a series of stage managers, designers and department heads to relay the information. The designer *did* have several photo references of Irish tinkers using an anvil of similar proportions...perhaps its a regional thing?
Other than a growing pile of steel mosquitos and spiders for the yard, I haven't given a thought to sculpture, Bob. My Missus does a lot of the sculpture for the theatre and her talent is rather humbling. A few years ago she built an amazing 13 foot tall statue of the Egyptian God Ra using pink styrofoam over a steel/plywood frame. She roughed it out with a chainsaw and carved the details with an olfa knife. A quick topcoat of latex stucco and it was ready for the gold leaf. Her speed and accuracy were amazing...think I'll just stick to woodwork and bangin' bits o' metal together....Rob
Todd Hughes
>As well as being called a Bick Horn or "Stake" often you will hear them called a Stump Anvil. Have never seen one shapped like the one you made with the one end that swoops down....and i have seen lots. Most common is the type called a "Blow Horn " stake and it shaped like the round end of yours but other side has a wider horn that is hollow on the underside.Not many would be this tall though coopers did use one that is tall like this to rivet hoops.On a real one you never, but never want to put one in the hardy hole of an anvil because the bottom of the Stake is tapered to fit in a plate or a stump and will get wedged into the hardy right quick.Hardy tools some of which look like small examples of a Bick always have straight shafts.
Actually according to about everything i have read most Tin Tinkers didn't take many tools with them to do repairs instead mostly just sold the tin that they made at thier home base during the off season.....Todd
