Questions, questions, questions
Kerry in FortSask
>Hi again,
Last night I finished planing a 4' x 10" red oak board, to be used in a project I started a little while ago. I'm fairly new to woodworking and very new to the hand tool thing and have been reading what I can both online and in print. This is the first time I've tried dimmensioning a board totally by hand, and it was a blast (and exhausting!). I've got a couple of questions for you folks who do this all the time:
First, how much faster does it get once a person has been at it a while? It took me a couple of hours to get the already quite straight board flat and planed to thickness. What I did was to go over it with my #4 1/2 set for a fairly deep cut, then with my #5 set for not quite so deep a cut, then again with my #5 but this time set to take a fairly thin shaving. I repeated the process on the other side, using winding sticks to get the faces parallel.
Second: I don't have too many planes (yet). I have a fairly old made in Germany no-name #3, an old made in Canada no-name #4, a Record #4 1/2, a Stanley #5C, a Stanley #7, a couple of Stanley block planes and a Veritas apron plane. I just bought a #78 off ebay, but haven't recieved it yet. So the question is did I go about this work in the right order using the right planes? I read in L.Lee's book that the #4 1/2 was suited for removing a lot of stock quickly, so that's why I started with it. Yet, I thought I'd read somewhere that it was a good final smoothing plane? If I want to set one plane up for starting the job (scrub plane?), should it be the #3, #4 or #4 1/2? The only reason I didn't make use of the #7 is that it was another recent ebay purchase and I just haven't had time to lap the sole and clean it up.
My 12 year old came in when I was working and said: "you're face is all red, how come you don't just use your power tools to do this?". I just smiled, and dripped sweat.
Thanks in advance for any advice,
Kerry
Re: Questions, questions, questions
Sounds to me like you...
Scott Burr in Ben Lomond CA
>Have the 4.5 and the 5 reversed. The 5 is a jack plane and should be used for initinal material removal and general flatting (i.e. set for a deep cut). Then you follow up with the 4.5 set for a very fine shaving to do your final smoothing. Other than that it sounds like your aproach is correct. Save the 7 for edge jointing and flattening large boards.
Keep up the good work...work? this is fun!
Jim in Burlington Ont.
Jim in Burlington Ontario
>You need that #7 in service and ready to roll. It depends on wether it was red oak or white. I start scrub if it's really rough then 5 then 7 last very fine cuts with a 4 1/2. You might want to splurge and get Rob Cosman's rought to ready video. Should take about 45 min IMO.
Larry Marshall
>The thing I do differently is to begin with a scrub plane. Mine's not a true scrub plane but rather an old Record #4 where I've ground a good sized radius (about a 3" radius as I recall). This allows you to peel wood away pretty quickly to get the board to thickness and to remove most of any cup that exists.
I enjoy handplaning a lot so this process is appealing to me. That said, when I need a lot of boards for a large project, I hand the wood to my tailed apprentice to get it to thickness. I can hear the hand-tool lightning gods loading up now:-)
Cheers --- Larry
www.woodnbits.com
Jonathan Peck -N.Y.
>Larry,
I think you've found your soul mate. You still haven't picked up that scrub plane yet? You know you still want one.....bad! Please ping me on the weekend so I'll remember to throw that #80 in my bag for you.
Later
>Preparing stock by hand is a matter of progressing from serious hogging of wood that leaves the surface pretty rough to finer and finer approximations of flat and smooth.
I'd suggest a scrub plane. People make them from No. 3s and 4s. I haven't done this because I have a Stanley No. 40 I picked up used (though I have a sort-of No. 3 that I plan to modify some time, just so I can compare it to a true scrub). I like the scrub.
Once you've got it more or less true, you use other planes, jointer or jack being the commonest, to get it flat, followed by a smoothing plane as needed.
I did more or less what you did in my earlier years, and it takes a LONG time. With a scrub and intelligent use of the other planes, you cut the time in half.
Michael R
>I have a no.40 also, but before I got it, I modified a no-name no.5. I set the frog back all the way and ground a fairly shrp curve into the blade so it doesn't cut full width. Depending on the situation, I often like the extra size and weight of the no.5.
Kerry in FortSask
>Thanks for all of the advice. Sounds like I should be looking for a scrub plane of some description. I'm so reluctant to mess with the #5 that I have because it seems to work so nicely as it is now. It's the first plane that I've lapped the sole on and filed all the mating surfaces flat. I'm going to lap the sole and re-sharpen the blade on the #4 1/2 and will try it for final smoothing next time. Maybe I'll put a radius on the #4 blade and try that for use as a scrub, I kind of wanted to get an old Stanley #4 anyway for a smooth plane.
I started lapping the sole of the #7 last night but I need to get some coarser material to remove metal faster. There appears to be a slight hollow in the front of the sole, towards one side right around the front knob.
Thanks again,
Kerry
One more idea...
Jonathan Kaplan (OR)
>All the above comments are right-on, of course, but one additional thing to think about is this: why thickness wood at all when using hand-tools? Of course, if boards are warped, etc., you need to get them all flat and then to the same thickness, but in general, there is often no good reason to make a board thinner... Sometimes there is a good reason, and then the scrub etc. is the way to go, but often I've found it just doesn't matter that much how thick the board is, as long as it is flat and even...
Best,
jk
