A different sort of plane sole flatness problem.
>I think that I have finally figured out why I have had so much problems with my HNT Gordon smoothing plane. The old sole not flat in front of the mouth problem. That's the second time this week! (to use the immortal words of Maxwell Smart :-) I also bought recently (okay, not this week) a Mathieson coffin smoother recently but this time I knew there was a problem but there was plenty of life left in the plane.
Anyway, back to the HNT Gordon plane. I have fussed and fiddled with this plane for what seems like forever. The iron is definitely sharp enough so that ain't the problem. In frustration last night at the end of yet another fiddling session, I put my starret rule against the sole and lo there was daylight at the leading edge of the mouth.
The leading edge of the mouth is actually brass on this plane and the body is made of ironwood so using another plane is not going to fly. So it looks like sandpaper and a flat surface. Sigh!
What I can't figure out is how this happened. Right now the relative humidity would be measured in negative numbers here so I think that it has always been this way.
I'll get back to you all on the results of this.
What I did try with this plane that works very well is using it as a scraper. With that thick iron even on the hardest wood there is no chatter. My Stanley 112 skips and jumps all over the place on this stuff. The only problem is that it tends to clog after more than two passes.
