Flattening the backs of chisels
Jonathan Peck -N.Y.
>I don't find it hard to believe that anyone spending 3 hours flattening the back of a chisel would wind up with and edge that crumbles after a few blows with a mallet. Hard to blame the tool for bad technique, but we all start here. Sharpening can be likened to the Holy Grail of woodworking and there is no substitute for practice and experimentation with different methods and materials to obtain what might simply be called sharp on a stick.
Whether you choose to buy a $50 A2 steel chisel, a $10 A2 steel chisel or rumage through the $1 rust barrel and prefer high carbon tool steel you will still need a fair amount of knowlege, technique and practice to get an edge that will hold up. This is an area that I am constantly trying to improve in. I'm sure all will agree what a pleasure it is to work with a sharp tool that will hold an edge.
There would seem to be no shortage of opinion in contentious topics, but I find the sharing of technique should be in greater supply. Most might find defending an opinion much of a game of words as opposed to the discussion that may follow in the actual debate of a prefered technique or method. Many might also find that they are indeed wearing the Kings new clothes when pressed to explain how they came to this conclusion or that. This to me is the essence of why we are here - to learn from each other and share in the passing along of knowlege as if the master to the apprentice would not understand the risk in leaving ones own comfort zone to explore new techniques (in a public forum -YIKES!).
But I digress....I would like to share my techniques that I use for flattening the backs of chisels with this group. I use different methods and materials depending on what I'm working on. Say for instance, I would not approach a LN chisel the same way as an old Witherby or even a two cherries, but I doubt that it would take me much longer to get the Witherby ready for work as it would the other two brands, and all should hold an edge....yes all.
I will F/U with a post on my methods, please join in (sorry if this sounds preachy)
Regards
Jonathan
