Boring flat bottomed holes in bronze for plane...
Jonathan Kaplan (OR)
>Hi,
I�m about to start work on an odd-styled plane (of a sort I recall from a series of posts back in the days of the �pond). It's basically a �Krenov� style sandwich, but the outsides are of bronze rather than wood, and the throat adjustable by moving the �captured� piece of wood in the front. One thing I�d like to do is recess the bolts holding it together into the bronze, but I can�t figure out what tool to use to bore relatively nice, relatively clean, flat bottomed holes in bronze... The holes should be about 1/2" wide and perhaps 1/4 - 3/8" deep.
Thoughts? Suggestions?
Thanks!
jk
Re: Boring flat bottomed holes in bronze for plane...
don langton
>A centre cutting end mill will produce a neat, flat-bottomed hole. These cutters are normally 2-flute and called slot drills. Just check with the seller that they are centre cutting - as multi-flute cutters tend not to be. I'd be inclined to mill the hole undersize (with a smaller diameter cutter) to take out the waste, before using a (finishing) 1/2 inch cutter.
Luke Herzberg
>A counterbore would be the best option. You could look at McMaster Carr, MSC or somebody similar to see the different types. If a guy felt like experimenting and breaking things while believing he was saving himself some cash (the route I would end up trying), it may be possible to put a flat grind on a regular twist drill...probably would need to start the hole with a standard bit. Good luck.
- Luke
Bob Hackett
>A counterbore is what you`ll need.These are used to sink allen head hardware flush with the surface,among other things.You drill the hole for the bolt shank size first and the counterbore has a pilot to guide from that hole.
One small tip here.Bronze tends to be a bit"grabby"when drilling.You can prevent this by grinding small flats into the cutting face of the drill.This turns the action from cutting(and grabbing)to scraping lending more contol and a cleaner hole.
Mainely,Bob
Thanks for the suggestions!
>Thanks for the suggestions and tips. I'll let you know what I decide to do and how it goes... :)
jk
