THE WOODRAT IS BACK!
Stanley 112 vs 12 scraper
Kudzu
>Would like to hear from people that have used both and what the practical differences are. I have been watching Ebay for a 112 for a while not but still waiting on good deal.
Due to the prices I am giving the #12 and 12 1/2's a second look. Just wondering how much easier a 112 is to use if any at all.
Re: Stanley 112 vs 12 scraper
Christopher Fitch @ Memphis
>Define what your good price is for a #112 and then compare to the Veritas scraper plane, this one:
Veritas� Scraping Plane
From my understanding, a Stanley 112 will be as much or more than the Lee Valley plane. If the price is right, I suggest getting one of those.
I don't know anything about the #12. Perhaps Mr. Leach knows something: #12 Veneer scraper
Now if you *want* an older tool (nothing wrong with that), then ignore my advice.
Jeff
>Thanks, had not seen that one. I think I had looked at the Lee Nielson and it's around $200? Have you used one of the Vertias scrapers? Price is attractive for sure.
Veritas Scraper Plane
mfitterling
>I have had the Veritas scraper plane since Christmas. Lately, I have really been putting it through the paces, scraping glue lines in glued up boards, lots of boards. THe plane is superb, and it has an advantage over the 112; you can put a bow in the iron that helps eliminate edge lines. It just takes a couple light passes with a burnisher to get a nice cutting edge. You have to play a bit with adjustments at first, just like any scraper plane, but once you get it you will get shavings like this.
Jim in Burlington Ont.
Jim in Burlington Ontario
>Hate to jump on the bandwagon but after using the Veritas for a few months now it's fantastic.
>I *just* got mine in two days ago. I have planned on buying it for some time now, and I finally bought it. It is a nice plane.
Tim of San Leandro
>I've had my Veritas scraping plane for a week....great stuff. Just like their other planes.
Other way to go...
Scott Burr in Ben Lomond CA
>The 12 will have the adjustment as the 112 (12 1/4 and 12 1/2). I perfer the footprint of the 112 over the 12's (it's longer, is held like a plane and not a scraper). Good luck trying to find a 112 on on the bay, they are a "collectors" item and go for a preium. You can ger a LN 112 for less than a Stanley most of the time. I got a bladeless Stanlet 112 for less than a LN (no LV version at the time) and put a hock iron in it, it works fawlessly. There is a learning curve to these planes, depending on the indvidual it can be quite daunting. I never realy had a problem setting one up, just lucky I guess.
That said, you might want to try an Stanley 80 or equlivent or even a LN85. These are simple to set up because of the lack of adjustments and are fine workers. I'd stay away from the No. 81 it's handles are low and it can be a real knuckle dragger DAMHIKT. Lot's of choices out there.
Skip in Falls Church
>I have a #12 I picked up off ebay a few months ago and I love it. I have one that was altered by adding a rosewood sole - which I had to replace. OTOH, it came with 3 blades, 2 Stanely and 1 Atkins. I'm still getting the knack of using it - keeping a grip at the end of a board can a bit tricky.
I've been using it on some Honduran rosewood that followed me home (at my wife's insistence) when I got the rosewood to replace the sole on the #12. (Is that something like cannibalism?)
I don't have a regular scraper plane of any sort, however. I would think that a scraper plane would make the stroke at the end a board easier to control. But the #12 really does work well and is a lot less painful on the hands than a handheld scraper.
Do you sand after scraping?
Tom Colligan, Peoria
>After you've planed and scraped do you still sand? Or, does the scraper eliminate the need for sanding? Tia,
Re: Do you sand after scraping?
>It depends on how the wood looks when I get done. Usually the wood looks good enough to skip sanding. If I do feel I have to sand, it's usually with 220 grit. I normally reserve the sandpaper for the finish though.
Ernie Miller Topeka
>I got mine for christmas it is a great tool definatly worth the price. the improvments make it a must have
Todd Stock
>You might look at the LN 85 - nice width, and less likely to chatter than the 112's.
