Broke blade adjuster
Jim in Burlington Ontario
>The blade adjuster on my 609 broke the yoke snapped in 2 places. Can I get a replacement somewhere? Can you drive the pin that holds it in out or do you have to drill it? Thanks Jim
Hi Jim...
Scott Burr in Ben Lomond CA
>I'm lost here. What type of plane is a 609?
Re: Broke blade adjuster
>Not sure what you mean by "609", but if the number is a typo and the plane is a regular bench plane, you can drive out the pin that holds the yoke pretty easy if you are careful. I try to use the right size punch, but if I can't find my punch I have done it successfully with a nail and light taps. I remove the frog from the plane, and try to support it in a way that it won't break. I can see if I have the part if you can post or e-mail a picture.
Re: Broke blade adjuster *LINK*
Eric Hedberg
>Jim,
Woodcraft carries replacement parts in their planes section. You have to dig through a couple of levels to the replacement parts, but they probably have what you want. They refer to it as a "Y".
If you can't fix it let me know. I'll take it off your hands and save you the trouble ;-). Good luck.
Just a typo 608 thanks
>See if I can get the pin out I still feel a little sick about it.
Thanks To All
>Very nerve wracking stuff but it's done now.
