Block Plane/Lateral Adjustment Lever Q.
Joe Hurst
>Ok, all you block plane users,
I'm attempting to revive an old Miller's Falls that (I fear) may have been frankenplaned...
Upon disassembling the plane, I was surprised to discover that the lateral adjustment lever is THREADED. This means that I have to adjust the lever's height before attaching the screw (that holds the lever cap) into the body. Talk about fussy...if the lever is too high, it will push the blade away from the body; too low and it doesn't engage the blade right.
SO...my question is: Should the lateral adjuster be threaded, or is it OK for it to turn freely on the main screw? I don't have another plane to compare this one to.
Thanks in advance,
Joe
