laquer removal from irons
Mike Hopkins Devon PA
>What's the fastest and easiest way to remove laquer from a set of chisels and a few handplanes. Sandpaper? Laquer Thinner with some sort of abrasive?
Thanks, Mike
Thanks, Mike
Re: laquer removal from irons
Steve Wargo
>Soak in Laquer thinner and then #000 steel wool. It worked great on my chisels
Jim in Burlington Ontario
>I like a tall thin container let them soak for a few minutes and wipe it off with a rag then make sure to properly dispose of the rag.
Joe Rogers, Northern Virginia
>Just spread out the rag and allow the solvent to evaporate in a well ventilated areaJR
Charles
>Mike, I've always left it on. The part that needs removing is removed when you hone the backs and bevels. Consider the rest rust protection.
>I have always worried that the lacquer will clog my stones.
