Throat Plates on Infill planes
Dan Clermont in Burnaby
>I've always wondered whyInfillplanes have throat plats for the bottom inch or so followed by an infill up top.
I understand the metal throat plate is there for stabillity but why not estend the hardwood for the rear tote all the way down to the throat opening. Sort of like a wooden plane which will help dampen vibration.
Also wondering if you can close a throat up on an infill using a piece of hardwood glued to the throat plate and then angled properly to meet the hardwood for the rear tote. I was thinking you could use this method to close down an oversizedd mouth or change the bedding angle.
Those were my pondered thoughts over the weekend.
TIA,
