Japanese Chisels
Japanese Chisels
Japanese Chisels
Eric Lund
>New here. I've been lurking for the past few weeks, and I've notice there are a number of people here that use Japanese chisels. I recently bought one from Woodcraft (12mm) to play around with. I figured I'd be less annoyed if I messed one of those up than if I messed up a Tasai.
Of course it has the hollowed back. There's not a lot of metal between the edge and the hollow. Now I've heard the term "tapping out" the hollow, but I've not really heard this described anywhere. So, I'd appreciate if someone would describe the procedure, so that when I get to the point where it's necessary, I know what to do.
Thanks,
Eric
Re: Japanese Chisels
Pam Niedermayer - Austin, TX
>Describing tapping out is just too big a job to do well in a forum, get Odate's "Japanese Tools..." book and start studying. Besides, it will be a long, long time before you'll need to do this.
The ura is supposed to be very small.
Pam
>I had the same thoughts as you when I first began using Japanese chisels about 4 years ago.
I do not tap out my chisels. As far as I am aware, there is no need ever to do so. The act of smoothing/removing the wire edge each time you sharpen serves to maintain the "flat".
My question about this process is whether Japanese chisels eventually become "thin" (especially across the hardened steel laminate) by following this method. I'm sure it would take a very long time, if this was the case.
Eric Lund
>Thanks,
I think I might actually have a copy of that around here somewhere.
It may not be as long as you may think. I kind of picked it up on a spur of the moment purchase. On getting it home, I've noticed the edge is not perpendicular to the sides. It's not grossly out, but it will take a bit of grinding (on a coarse waterstone) to straighten it out.
>I'm a bit lost here. What may not be as long as I may think?
Your chisel might be kind of good to use as a slight skew rather than automatically grinding away the cutting steel, you could straighten it gradually as you go. However, I tend to be more casual about perpendicular edges than I am about the width of the ura, a constant thickness of the cutting steel, perpendicular shanks, and the like.
Pam
Eric Lund
>Just looking for an excuse. I bought the Woodcraft version too mess with. No point in accepting an edge out of alignment when regrinding the edge let's me experience more of the ins and outs of working with this type of tool.
If I "have to" grind it back to the point where I need to tap out the edge, it's just part of the learning process. I don't "quite" consider it a throw away, as I will get lots of good use out of it, but I won't be afraid to fiddle with it. Then, I'll feel much more comfortable when the budget allows me to buy the more expensive tools made by a "known" maker.
Cheers,
Eric
