Veritas #7 or #8 ??
Derrell
>Anybody know if Veritas is ever going to make a #7 or #8 bench plane? Or maybe another question is if you have a #6 would you use it most of the time instead of a #7 or #8?
Veritas #7 or #8 ??
Derrell
Re: Veritas #7 or #8 ??
>Can't help on your first question -- some of those more closely wired in to the ruminations of the Lee Valley Gang may be able to help.
Your second question is a variant of that old saying about "give a kid a hammer, and everything s/he finds is a nail." If the longest plane you've got is a #6, you'll use it for long plane purposes.
I do find that there's a discernible difference in effectiveness for jointing between my #6 (which I love and use often) and my #8, in favor of the longer plane.
John in NY
>I asked them (Lee Valley) that question and there response was maybe but nothing planned right now...
No 6 OK - No 8 specialty plane and quicker
Andrew F in Australia
>Hi Derrell,
I use a No6 plane for all bench work (our trade training). It's possible and fairly easy to joint 8' long boards with this, but, the No 8 would do the work far quicker.
If you were a masochist, you could joint boards with a block plane successfully.
So, my answer is that a jointer plane gathers more rust than others in your shop - if learn how to use a plane properly, a No6 will see you out without the expense of a jointer.
But then again, if the money's burning a hole in your pocket and you want to buy a jointer, either a No 7 or No8 will suffice - I'd say weight of the plane (swinging a No8 for extended periods is tiring) and cost where two reasons that the No.8 were discontinued before the No7.
Hope that this helps,
Cheers,
Andrew
Re: Veritas #7 or #8 ?? *LINK*
Roger Nixon
>The Veritas #6 has different dimensions than the Stanley et al. See Lyn Mangiameli's review of this for comparisions.
Lee Valley No. 6 Review
Derrell...
Rob Lee
>... one never says "never", but not in the forseeable future...lots on the list ahead of that solution.
Cheers -
Rob
Thanks Rob
Derrell
>Thanks to all for the info. My question was mostly based on curiosity. I was looking through the Lee Valley catalog and just noticed that there was no #7 or #8.
Rob, thanks for the inside info. I am sure I'll be sending some $$ your way soon. There are just too many good looking things in that catalog to pass up (plus my sister gave me a nice LV gift certificate for Christmas).
And no offense is taken over misss sppellinggs. We are all friends here.
