New Veritas Spokeshaves
Eric Hedberg
>Just got my new Veritas spokeshaves from Lee Valley. These are definitely worth a look. The fit and finish is superb (especially at the handle connections) and the balance reminds me of my Millers Falls 2. Excellent bedding of the blade and for those of you that have heard me diss the adjusters on the Record and Stanley's, these adjusters are really sweet to use with very tolerable backlash. If you are looking to get or expand your spokeshave collection (without contracting your budget) these are worth a try. Congrats to the Lee Valley team.
Re: New Veritas Spokeshaves
Wendell @ Murphy, TX
>Everyone is raving about these shaves. I am getting to urge to buy them even though I have no idea how to use a shave or what to I'd use them for. You people are evil :-)
Wendell
Andy Lincoln in Dearborn ,MI
>Wendell,
Just a note to let you know you are not alone.I have no apparent(I think) use for a spokeshave at this time,nor a real understanding of what and when to use one,BUT they look so nice and well made I am having a hard time NOT buying them.
Andy
kees
>the secret is for you folks: you want to know what's the difference with LN/boggs. Isn't it?
kees
GolfSteve in Calgary
>How do you like the shims that are used to adjust the mouth?
Are you able to offer a comparison to the LN/Boggs shaves?
Eric Hedberg
>Since I literally just got them, I've only had a little while to set them against the wood. I've never used the LN shaves, so I can't make an unbiased comparison. I know some people at WoodCentral have them and like them (LN and Boggs no surprise). The only complaints I've gleened is that they are better suited to finish work.
I haven't tried the throat shims (color coded for size) and eventually will. In my experience (and bias) the throat opening hasn't made a big difference. I use my spokeshaves most often for concave curves where the geometry of blade angle, points of contact, and wood grain can make every situation unique. Sometimes a wider throat (for me) does a better job of clearing the uneven chunks left after bandsawing.
That being said, the flat bottom has worked like a petite block plane. It took thin shavings and left a glassy surface without any shims.
Like any new tool, I still have a bit to learn about their personalities. I'm still getting used to the adjusters and am surprised that I actually like them (who knew). I also like how easy it is to pop the blade out and return it to its original position. I am amazed Lee Valley has packed these many features into such a resonably priced (pair of) spokeshaves.
>When the handle for your snow shovel breaks off, you can shave the end of the handle so that it will fit in the socket.
very nice :)
John Truxell-Svenson (jvs)
Great Idea!!!
>Of course in Texas, I would have use gardening tools instead of a snow shovel. May be I can even pass them off as a household expense instead of coming out of my tool allowance. I can just hear it now "But Sweetie, the shaves are for maintenence of your garden tools, really!!!" Oh well, it was a nice thought :)
Wendell
buy them and a need will come
Bill Tindall, E. TN
>Sounds corny, but if you don't have a tool you tend to avoid making things that require it. Once I had some well performing spoke shaves I seem to find all sorts of ways to use them, including making the occasional handle. A lot of what you might have used a file or rasp for you will now do 10X faster with a shave.
Re: buy them and a need will come
>...tend to avoid making things that require it
...or, worse, declare those things to be ugly, and below their dignity to even consider making, or having in their homes. From there, the downward spiral continues, until they begin to ridicule the objects and their prices and the people who build them, as "dinosaurs" or "artsy-fartsy", or [explicative deleted]. Before you realize what is happening, they'll be breaking out the torches and pitchforks...
...and the spokeshaves, to fix the old torch handles.
Isn't That
Howard Toronto Man
>the way it's SUPPOSED to be?
Over the years, I've bought a fair bit of gear because I liked the way it:
- was made
- looked
- was described
I duuno, I thought all WWers respoinded to the beauty of a tool.
My 2C. Howard
Linear and nonlinear
Eric Hedberg
>Maybe it comes down to this. In woodworking and in life their are the linear thinkers (planes) and the nonlinear thinkers (spokeshaves). Or as my grandfather once told me the best things in life have curves (I think he was talking about woodworking). Pick up a good spokeshave and you'll be surprised how often you use it.
Re: Great Idea!!!
>I was only half-way kidding. After reading all of the praise of the Veritas LA spokshave, I bought one. I had actually not used it, until one day my wife broke the handle off of a garden rake. I sawed it off clean, and, while she watched in the carport, shaved the stub to fit into the socket on the rake.
I was quite proud of myself, and commented on the obvious utility of elements of my handtool collection. ;-)
Re: Great Idea!!!
>So, Don, did she respond,
1. "Yes, honey, that sure is neat. Why don't you go out and spend some more money on hand tools, and I'll never make sarcastic comments again?"
2. "So, in about the time it would have taken to go buy a new handle, you were able to give me a rake with a shorter handle...and how much did you pay for that thing again?"
Or was the response somewhere between?
Give me a few days...
Christopher Fitch @ Memphis
>...and I'll let you know. After all this discussion, I broke down and ordered a pair.
I'll have to give my Veritas Low-angle shave to my brother.
I have both the Bogg's shaves from LN and I have the curved small shave.
I found that the Bogg's shaves are indeed for fine cuts. They do a nice job in that area....
Blast you guys...
Greg B�tit, Vergennes, VT
>I own more spoke shaves than any reasonable person should. The Jan LV catalog just came in, and you guys start yammering about the new spoke shaves pictured on the back cover.
Form and Functionally they look a lot like the pair of LN Boggs shaves, perhaps not as purdy, but you can adjust the throats of the LV ones, and they come with an adjustment mechanism, and a place to put your thumbs. The round one has more radius than the LN Boggs, I can tell from the picture (you can hardly tell there is any radius on the Boggs, but its there, and in use is functional compared to trying to do it all with the flat one).
Did anyone mention that you could get the two LV's for less than the price of one LN Boggs? Looks like another great well thought and engineered tool offering from LV, and I'm having no luck resisting adding them to my coll ^h^h^h^h stable of basic, essential tools. (This, despite the post Christmas condition of my finances)
Greg
Re: Blast you guys...
Eric Hedberg
>I think Christopher has you beat in more spokeshaves than is reasonable, but of course it is unreasonable not to have a lot of spokeshaves. (Kinda like accessorising) Yeah, the price is pretty amazing. Wait til you see them in person. Bronze is pretty, but iron makes a serious shave and these really are good looking in person. Remember, its not too late to return those unwanted presents!
>hehe...
I admit I do have a number of shaves; 6 currently ... soon to be 8, then it will be 7 after I give one to my brother.
However, I know a number of people on here have many more than I do.
One of the biggest lessons I learned about hand tools is to buy quality in bulk!
kees laan
>Already more opinions?
regards,
kees
