Fun with planes
Fun with planes
Fun with planes
>I'm halfway through (yes!!) shaping the railings for the porch steps, and wanted to show off. The picture below is of, to the left, a section of the upper railing, trimmed off in the course of assembling the dogleg transition from the porch post to the steps (comes out about 2-3/4" level, then slopes down at the angle of the steps).
To the right is the sequence I followed in shaping:
1. Hog out the wood for the hollow section with the scrub plane.
2. Shape the hollow section with a round (by amazing coincidence, the one hollow and round base set I have for my No. 45 is the right diameter to match the existing railing pattern).
3. Plane the 1/16" "step" at the top with a No. 78 rabbet.
4. Shape the round section and the flat transition between round and hollow first by a little bit of hogging with the scrub again (about two strokes) and then finishing with a block plane.
I'm getting the routine down -- doing the final runs of railing, between middle post and lower post, should be a lot quicker than the first attempts.
Observations:
1. Boy, am I glad I got a scrub plane a few years back! It is such a timesaver.
2. Round bases on No. 45 planes are not the easiest of tools: a) they seem to want to clog (I actually, at one point, took the iron out and sprayed silicone lube on the throat, which seemed to help), b) as with all molding planes, I guess, an absolutely perfect match of shape of iron to shape of sole is imperative, c) they slide off the surface being planed with remarkable facility until they get a groove going (using the usual approach with the 45, starting at the far end and doing short strokes, moving back until you've established your groove, helps).
3. Once you get the system down, this kind of shaping goes quickly. I'm going to time myself for the final runs of railing.
Re: Fun with planes
Re: Fun with planes
>Hey Bill, I think that's quite an accomplishment. How many feet of railing do you have to do? I don't blame you a bit for wanting to show this project off as I know that I myself would be quite proud of myself if I was doing the same thing. You'll be able to look back on this railing for years and take Pride and Pleasure in knowing that you handcrafted it using only simple handtools.
What cha' gonna do with all those shavings that are accumulating?
Todd O.
Re: Fun with planes
Re: Fun with planes
>It's good to hear of someone successfully using these planes as I suspect they were mostly designed to be used - for carpentry.
Re: Fun with planes
Re: Fun with planes
Greg B�tit, Vergennes, VT
>When I bought my present home 17 years ago I needed to replace 20' of rotted fascia crown molding that had been made a 100 years or more ago. I brought a sample of it over to a friend and a week or so later he brought me 40' of a perfect match. He described the sequence of planes he used (he has a wall full!), but at the time I lacked adequate appreciation of how fortunate I was to know someone with the proper tools who also had the skills to use them.
Greg
Re: Fun with planes
My point was...
>I neglected to conclude that remark with the whole purpose of my post:
You should be truly proud that you can grab a tool and make whatever you want. It is not just an acquired skill, it is a statement that you will not become a victim of the one-size-fits-all lemming run that seems to mark modern times.
Greg
Re: Fun with planes
Redwood: yes
>Yes, old growth redwood salvaged from the original joists on the porch -- 22 foot long 2x6's, true 2" thick. The design requires 1-3/4" thick stock, which is awfully hard to get out of modern nominal 2" stock. For the lower railings at the top run (from middle post to porch), I ran out of the joist stock and had to glue up stock from a 2x6 ripped to fit -- amazing how much wood wound up on the shop floor.
Which reminds me, to answer Todd's question, the shavings went into the yard waste recycling bin. We don't have any hamsters, and redwood splinters fester anyway, so I'm not sure I'd want to expose any little furries to the hazard; and it's acidic enough that it wouldn't make good compost in our small compost bin.
Re: Fun with planes
Follow up comment
>One thing I forgot to mention: the reason that the round plane was slipping off to the side was that I was initially trying to plane "upright" to the bench surface. As soon as I began to plane "upright" to the surface I was planing -- that is, leaning the plane out so that it was at right angles to the surface I'd created in Step #1, the slippage diminished considerably.
As I write this, the little observer at the back of my brain says, "Well, duh, cowboy," but for some reason, it wasn't as obvious at first as it is now.
